View Single Post
  #17 (permalink)
Old 10-27-2005, 09:03 AM
vividjazz's Avatar
vividjazz vividjazz is offline
Someone that Posts too much
vividjazz will become famous soon enough
Quote:
Originally Posted by hotsauce
hi...just wanna ask what rubber did you use for the tower bar ??? can u post pics on how did u install it thnx
You could use Nolthane like in aftermarket bushes but I just used some rubber orings made out the same stuff as typical rubber suspension boots and a couple of bits of foam with addesive on one side.
Installation
1) Take the plastic cover caps off each side.
2) Undo the nut on each side
3) put on rubber and/or foam on
4) put the bar on
5) screw the nut on each side back down (don't over tighten)
Sorry, didn't take any pictures as I did it but if your not confident doing it any mechanic can do it for you in about 10 mins.
