View Single Post
  #81 (permalink)
Old 11-07-2007, 10:08 PM
GUNDAD122 GUNDAD122 is offline
GUNDAD122 is on a distinguished road
Mine Do Not Lok Like That, Mine Are 8mm Hex Nuts In About The Same Location As The Ones In The Picture, On The Drivers Side There Is A Black Plastic Cover That Snaps Off Covering It. Remove Cover And Look Behind Light Assembly And You Will See It. I Used A Little 8mm Box Wrench To Get At It, Youcan Only Turn It About An 1/4 Turn At A Time Due To Space Restrictions. I Put In Ge Nighthawk Bulbs, They Were No Better Then The Factory Ones. Good Luck Larry.
