View Single Post
  #98 (permalink)
Old 11-08-2007, 10:13 AM
BigWinston BigWinston is offline
BigWinston is an unknown quantity at this point
Just to let you all know that I used this guide as the basis for my AUX input install on my FIT base. Seems to be working perfectly, although I made a small modification and used the Radioshack 5 terminal Auxillary face mount device. Also, I wasn't happy soldering on to the end of the pins, so if you just unscrew the rear cover (1st one to come off in order), it's much easier to solder to the flat horizontal of the pins there with a fine tip soldering iron.
Thanks again for the guide and all the comments, it was a great help!
