View Single Post
  #18 (permalink)
Old 11-25-2005, 06:39 AM
hotsauce hotsauce is offline
hotsauce is on a distinguished road
Quote:
Originally Posted by vividjazz
You could use Nolthane like in aftermarket bushes but I just used some rubber orings made out the same stuff as typical rubber suspension boots and a couple of bits of foam with addesive on one side.
Installation
1) Take the plastic cover caps off each side.
2) Undo the nut on each side
3) put on rubber and/or foam on
4) put the bar on
5) screw the nut on each side back down (don't over tighten)
Sorry, didn't take any pictures as I did it but if your not confident doing it any mechanic can do it for you in about 10 mins.
just installed ALEX japan rear tower bar...but im having problem with the sound...i already put a rubber orings underneath the bar but still i has a sound...HELP me out how can i eliminate the noise thnx
