View Single Post
  #23 (permalink)
Old 11-26-2005, 11:49 PM
vividjazz's Avatar
vividjazz vividjazz is offline
Someone that Posts too much
vividjazz will become famous soon enough
Quote:
Originally Posted by hotsauce
but if u dnt tighten both one side youll hear a knocking sound right??? did u put rubber orings above the tower bar were the nut is...?
What I mean about the sides is don't fully tighten one side then the other. Tighten one side a bit. Then tighten the other side a bit. Then go back to the first side and tighten a bit more. Then change sides tighten a bit more and so on until they are both tightened / torqued to 33-34lbs.
Yes put rubber/foam/soft stuff between anywhere where there is metal to metal contact to prevent noise.
I found the bar itself touched the top of the towers slightly creating a resonance throughout the bar. Following the same simple principal I just stuck a bit of foam under the bar itself on each end where it meets the top of strut towers. Noise gone.
__________________
Australian Honda Fit Jazz Club - www.ausfit.com
