little late
just incase you are still looking for an answer
there are four bulbs inside the hvac that light up all the knobs and switch for recc. or fresh air... there is just 2 holes on the bottom that the xtra light leaks out of ... they are #74 bulbs... just replace all 4 with your choice of color and it will shine thru the holes..
if you take apart the hvac you can see 2 holes directly above the little lenses in the white inner plastic piece, perfect size and location for some leds to shine down and out the lens (into the cup holders)
