Thread: DIY rear disc
View Single Post
  #72 (permalink)
Old 11-29-2007, 06:37 AM
isitafox's Avatar
isitafox isitafox is offline
isitafox is an unknown quantity at this point
Right got an update, got the following prices an they're a bit steep!
The caliper brackets are £91 each, hubs £120 each and then discs and pads are £40 and £30 but they can be found a lot cheaper elsewhere. Looks like the best and cheapest way is to go down the custom bracket route, that way we can retain our hubs and save a bit of money. One thing though, the spindle is built in to the caliper bracket on the fit so how do ya get around that?? Need to make it all work with the abs sensor. Other wise could you use EK civic rear brakes as my old EK had ABS and with it not being very old they may use the same system?? I'll keep searchin for as much info as pos!
