Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Reply
  #1 (permalink)
Old 10-22-2008, 10:08 PM
theloxmyth's Avatar
Fit Gadget Freak
theloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to livetheloxmyth relies on Rep Points to live
Exclamation Ignition light ring DIY for 2008 base model.
I do not accept responsibility for any damage to YOUR Fit unless I am doing the job for you. Nuff said!
Base model, GD3, with OEM keyless entry and OEM security system installed by me.
Following niko3257's lead in the installation of JDM DOHC SiR's LED ignition light ring...here we go.
Thanks JDM DOHC SiR!
Red wire to fused constant 12VDC.
Black wire to ground.
...Easy enough so far!
See niko3257's post here for other 'nuts and bolts' info:
Ignition Light Ring DIY
Thanks niko3257!
Yellow wire (Yellow wire) to green with white stripe by ignition switch.
(Read on.)
Blue wire to White with black stripe and silver specks behind instrument cluster.
(Read on.)
Take gauge cluster apart in three steps...
Bezel pulls away with slight force.
Four unnoticeable black circles note where the clips are located. Look hard.
Look for the four arrows and remove these screws.
Look for the 5 arrows and remove these screws.
Looking down at top of dash board where the gauge pod was. The wire you need to tap-in the BLUE wire to is the white and black stripe with silver specks, FIFTH FROM the LEFT at TOP OF CONNECTOR PACK.
Push in the retainer and remove the connector by gently wiggling it loose. YOU CAN SEE THE retainer in the next shot beside the black arrowhead.
Here is a close-up of the wire and where it is.
Tap-in and wire tie everything you do!
Next is the YELLOW WIRE (YELLOW WIRE).
The green connector show here is directly below the ignition bezel. (Sorry I did NOT show how to remove column housing in this pictorial. See niko3257's pictorial in the GE8 forum for these shots...Thanks niko3257!)
Tap-in YELLOW WIRE (YELLOW WIRE) to the GREEN with WHITE STRIPE.
Reverse gauge POD installation and enjoy being able to see the key hole in the dark, thanks to JDM DOHC SiR!
Thanks Dave!
Constant blue without the key inserted.
LED totally off with key inserted.
RED when alarm is armed.
Be careful out there...its a world!
__________________
Stay 'tuned',
Craigster
www.CraigTheLocksmith.com
www.ThePittsburghLocksmith.com
www.QualityLock.NET
www.PTLock.com
www.1Safes.com
"Never piss-off a locksmith."
Sponsored Links
  #2 (permalink)
Old 10-22-2008, 10:17 PM
kenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond repute
that's pretty cool. i was going to wire mine to the dome light harness with the delay circuit. but mine's only one color.
__________________
Fit#1: 08 FitSport Storm Silver Metallic (5MT) - My modded dd
Fit#2: 09 FitSport Taffeta White (5AT) - Her stock dd
  #3 (permalink)
Old 10-22-2008, 10:28 PM
theloxmyth's Avatar
Fit Gadget Freak
Quote:
I'm always looking for +Rep, even though its not important to some.
Thanks to JDM DOHC SiR and you, kenchan.
__________________
Stay 'tuned',
Craigster
www.QualityLock.NET
www.PTLock.com
www.1Safes.com
  #4 (permalink)
Old 10-22-2008, 10:38 PM
well, you got one from me.
__________________
  #5 (permalink)
Old 10-22-2008, 10:44 PM
JDM_DOHC_SiR's Avatar
JDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to liveJDM_DOHC_SiR relies on Rep Points to live
Great job....!!! now the GD guys know how to wire this up
__________________
2009 USDM Fit Sport AT .....got it !!!!!
Sorry Guys & Gals no more orders untill around late January 09 ...
  #6 (permalink)
Old 10-22-2008, 11:00 PM
theloxmyth's Avatar
Fit Gadget Freak
Quote:
Originally Posted by JDM_DOHC_SiR View Post
Great job....!!! now the GD guys now how to wire this up
Brother,
The area that the LED 'shows through' is small.
Do you think it would be wise to try to make the ignition hole a tad bigger on the drill press?
OR...should I leave well enough alone!
I'm leaning in the leave well enough alone direction!
__________________
Stay 'tuned',
Craigster
www.QualityLock.NET
www.PTLock.com
www.1Safes.com
  #7 (permalink)
Old 10-22-2008, 11:06 PM
I would leave it alone....
__________________
  #8 (permalink)
Old 10-22-2008, 11:11 PM
theloxmyth's Avatar
Fit Gadget Freak
OK.
Later,
__________________
Stay 'tuned',
Craigster
www.QualityLock.NET
www.PTLock.com
www.1Safes.com
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cruise Control for base model Minisota Fit Fit It Yourself : Discuss Do It Yourself-Repair and Maintenance 43 12-19-2008 10:59 PM
Fit Base Model tire availability cedric Canada Fit Forums & Clubs 16 07-05-2006 04:39 PM
Base model fit. vtbonehead New England Community 13 06-21-2006 12:08 AM
US base model stereo question rgrcmrn General Fit Talk 9 01-31-2006 11:25 PM
Is base Fit cost growing? Volk General Fit Talk 16 01-19-2006 06:54 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
