Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Reply
  #1 (permalink)
Old 10-31-2008, 07:46 PM
schutzenfester is an unknown quantity at this point
Toyo 205/45 ZR16 air pressure
I have a 2007 Fit with Honda factory 16" spoke rims with Toyo 205/45 ZR16 87w tires. (Proexes F24 PXF24)
Sidewall states 50 psi max. I know that is not the ideal pressure but the manual states pressure for stock tires that did not come with my new Fit when I bought the car.
Any suggestions for proper psi inflation?
Thanks in advance for your feedback!
Sponsored Links
  #2 (permalink)
Old 10-31-2008, 08:03 PM
rvall004's Avatar
rvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awardsrvall004 should get some awards
I will say 33 or 34 psi
__________________
I want one of these..can anyone donate some change
  #3 (permalink)
Old 11-03-2008, 02:58 PM
Interstate526's Avatar
Interstate526 is a jewel in the roughInterstate526 is a jewel in the roughInterstate526 is a jewel in the rough
i think it kinda depends. If you want better handling feel, and possibly better mileage, you could do about 40 ish. you'll sacrifice comfort though. rvall004 said 33-34psi , which is probably a good balance.
  #4 (permalink)
Old 11-03-2008, 06:46 PM
kenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond reputekenchan has a reputation beyond repute
for a car of this weight, 33-35 should be plenty....
but if you have the garbage ziex912's like i do, pump it
up to 38-39psi. it feels so much better.
__________________
Fit#1: 08 FitSport Storm Silver Metallic (5MT) - My modded dd
Fit#2: 09 FitSport Taffeta White (5AT) - Her stock dd
  #5 (permalink)
Old 11-03-2008, 10:04 PM
chimmike will become famous soon enough
uhhh, IIRC the factory Honda rims are 15".
are you talking the HFP wheels?
Either way, I do 35psi in all my cars for the street. Maximizes fuel economy without threatening wet-weather traction. Going beyond 35psi on most street tires will cause more possibly hydroplaning issues....and 35psi+ means less contact patch on the ground, so the handling won't be as crisp.
__________________
2007 GD3 Fit 5AT-stock
2003 AP1 S2000- RS*R ExMag GTII exhaust, Comptech intake
2007 Harley-Davidson XL1200C
65 gallon reef aquarium
No money.
  #6 (permalink)
Old 11-03-2008, 11:26 PM
for your tires maybe... but tires are all different and depending on the
application higher psi is recommended. but beyond 40psi is kinda iffy...
but those hyper milers use those crazy 50psi setup. well, kinda
crazy in my books but works for them.
__________________
  #7 (permalink)
Old 11-04-2008, 09:50 AM
tires are all different, yes. But in general, with cars, you shouldn't exceed 35psi, or your hydroplaning possibilities increase. There's an equation we used to use when I was in flight school to determine at what speed a tire has the most chance of hydroplaning, based on PSI. I'd have to look it up.
Beyond 35psi you're just trying to increase mileage, at risk of uneven wear and wet weather traction loss.
__________________
No money.
  #8 (permalink)
Old 11-04-2008, 09:53 AM
GD3-Fit's Avatar
I <3 SPOON
GD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to liveGD3-Fit relies on Rep Points to live
yea i'd go with 32-35psi to keep it safe
__________________
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Complete OBD II Codes List sLiVeRwOrM Fit It Yourself : Discuss Do It Yourself-Repair and Maintenance 11 10-05-2008 03:04 PM
Excellent Article on Tire Pressure from Officer.com RichXKU Eco FIT 40 09-29-2008 08:26 AM
Header xtreme General Fit Talk 3 07-20-2006 12:22 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
