I just drove my Fit around this evening and noticed some little weird things going on. Whenever I turned the AC on the headlights dim briefly and then go back to there previous state. Same thing happens when one of the windows are being rolled up.
Has anyone else noticed this happening or am I just an old ball of the group?
happens on almost every car I've owned. It's the extra amps being pulled on the startup of those systems, puts a quick strain on the alternator, then goes back to normal.
Only car I haven't really noticed this on is my old aerostar van but then again those lights were already very dim so it would be hard to tell if they got dimmer.
solbrothers, I'm just going to ignore that comment for now. Can't tell where you were coming from in that post.
Quote:
Originally Posted by Guinness
You may wanna go for HID conversion for your headlights... that will solve all problems and u will end up having brighter / nicer lights =)
I was gonna say you may need HID for winter driving but I am not sure if its all that dark in TX during winter... up north, its dark by 4pm... =\
Its not a problem, it was just one of those moments were you go, "What the heck is going on here?" The HID lights aren't really needed around here during winter but I have been considering installing up some in the future.
sorry, in not talking about you, im talking about HID headlights. unnecessary glare for other drivers and no real lighting gain. unless you do a full retrofit with projectors
i never noticed it in the several cars i have owned til i got the FIT and happens like u said when turn somethin on such as roll window up or down brief dimming of lights
__________________ 07 Honda Fit Sport, Eibach Springs, custom blue auto shift, knob, LED tails and 3rd brake light, CF hood, tint, 15" drag, CAI, CF rear spoiler
Perfectly normal! Starting current is several times the ampage when compared to normally running current. Since the battery can handle only so much...the starting current takes alot of the battery's ability thus reducing much of the other loads. An AC unit especially draws alot of initial current.
__________________
2008 Honda Fit Sport (Taffeta White)
Color matched body side molding. (Zeta Products)
17 inch Enkei Evo 5 rims.
OEM cargo cover, cargo tray, rear bumper applique, chrome exhaust finisher and door panel kit in silver.
JDM center console and JDM leather shift knob.
1997 Honda Prelude Base (San Marino Red)
WWRS lip kit.
17 inch chrome Motegi DPK rims.
AEM V2 CAI
OEM spoiler.
When I had my '08 Sport, I noticed the lights dimming each time the A/C turned on and off... It was very very bothersome.
This never happened on other cars I've owned in the past. I've had BMWs, four Accords, some Cavaliers, etc... I have yet to run the A/C on my '09 Sport while driving at night, but I will sure try it soon enough. I sure hope Honda addressed this going forward.
__________________
'09 Crystal Black Honda Fit Sport AT
And since our batteries are so small the effect is amplified.
since when do you guys think this has anything to do with the battery when the engine is running?
Have you ever heard of ALTERNATORS?
The alternator on this car is tiny. Any spikes in amperage pull when something is initially turned on is going to cause a brief dimming of headlights. Remember folks, the ALTERNATOR is part of the charging system, which maintains the charge in the battery
Oh, and HIDs? You think those use LESS power? Are you nuts? lol.
One quick way to fix this is to buy a audio cap and install it I was having the same problem till I installed my Car audio system and bam it was over and done my fit was the second Vechile I noticed it on the first was my 97 Dodge Neon Basically you should install a audio cap run it in series with your stock battery
HID's draw less running amperage than incandescent lamps. Why do you think OEM's started using them?
Also, the alternator being small is what causes those voltage drops, but if the battery were bigger (capacity-wise) it would mitigate the effect. I just swapped out my arthritic stocker for a Braille 3125 with 1380 pulse cranking amps! I can barely detect the headlights dimming when I turn on the defroster (A/C).
__________________
'07 MR Fit Sport MT
Aspec axle back, Megan Racing B-pipe
T1R Turbo kit, 6psi
Greddy E-Manage Ultimate, tuned by yours truly (and yes I'm damn proud of it!)
The most modified fit in Michigan!!
(that I know of)
