Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Reply
  #1 (permalink)
Old 11-03-2008, 10:02 AM
FitCanada_Girl's Avatar
Frequent FitFreak Poster
FitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to beholdFitCanada_Girl is a splendid one to behold
How would you rate the heating system in Fit???
Thought I'd get input from those with 1st generation Fits since you have seen a few winters by now. How do you find your heating system, especially if you're in colder climates?
My usual routine is to park with temp to max, fan to 0. Start up car, drive away (low engine temp light on). When low temp light turns off, set fan to 1. Once I feel hot air blowing out, I'll set to 2. Oh and usually I only use the vent setting or vent/feet (once air is hot) unless windows are fogging up, then set to windshield setting.
We've gotten a few 2 degree Celcius days and I've had my '09 Sport for 6 weeks now so can report on something odd. My prior car was a 2004 Mazda3 Sport, so another small car. I realize that heat is drawn from the engine to warm up the passenger cabin so until the engine is warm, no heat! However, once my Mazda3 started blowing warm/hot air, it STAYED that way and the temp did not fluctuate unless I switched the temp control/fan speed.
What I've noticed on my '09 Fit Sport is that the engine will warm up and blow hot air, but if I slow down, the air then blows cooler. If I STOP and idle (say at a set of lights), within 1 minute the air is blowing totally cool. I can feel it go from hot to warm to cold within that span of time. I monitored the temp closely this AM (now at 1 degree Celcius outside) to be sure I wasn't imagining this. No, every time I slow down, I can feel a perceptible lowering of the temperature of the air being blown into the cabin (left it at maximum heat, fan 1 all the way on my 40 km commute/45 mins). I timed it when totally at a stop...within 1 minute max, the air is totally cold.
Now my winters here in Sudbury typically run in the -20s to -30s (Celcius) range so this is a MAJOR problem. Sure, the cabin warms up once the car is moving fast but surely the temperature should STAY warm once the engine is fully warmed up, right? As I stated above, that's how my Mazda3 worked. Ok, a bit larger than the Fit but still not a huge vehicle...
Has anyone noticed this? I want some input before I book an appointment with my dealership. I'm wondering if maybe there's inadequate insulation of the engine compartment to account for the drastic cooling at lower operating speeds??? Any other ideas???
__________________
2009 Orange Revolution Honda Fit Sport AT (aka "GR8 Pumpkin")
Sponsored Links
  #2 (permalink)
Old 11-03-2008, 10:32 AM
Arisenfury's Avatar
Arisenfury is a name known to allArisenfury is a name known to allArisenfury is a name known to allArisenfury is a name known to allArisenfury is a name known to allArisenfury is a name known to all
I can't say I've noticed that problem with my GD. I'm only in New England so we don't see winters that cold generally. But I don't recall the car ever cooling down when I've stopped moving. Usually I find I have to turn the heat down after it really gets warmed up otherwise it gets too hot for me.
  #3 (permalink)
Old 11-03-2008, 10:44 AM
Quote:
Thanks! That's what I think that once the engine is warmed up and has pushed hot air into the cabin, it shouldn't then start pushing COLD air if I slow down/idle (with temp dial to max, fan at 1-2). Just doesn't make any sense to me...
__________________
  #4 (permalink)
Old 11-03-2008, 12:16 PM
accordguyintake's Avatar
accordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant futureaccordguyintake has a brilliant future
i think it might be because you have the "fresh air" setting on. When it is set on this, the faster you go the more airflow comes in, giving you more warm air. But when you're satationary the air is not moving so the fan does all the work. Dont feel the "air" but rather feel the vents themself. I seemed to notice a similar problem and that was my conclusion to it
__________________
My Name R Jason Truong
I... finally got a Fit! Tidewater Manual Sport!
Myspacee http://profile.myspace.com/index.cfm...iendid=4079714
I'm ACTUALLY IN 2 songs!! Anything You Want & Shes A Star or w/e.. haha give it a listen!! http://profile.myspace.com/index.cfm...ndID=369250710
  #5 (permalink)
Old 11-03-2008, 12:35 PM
Couple other threads point to this being a defect of my heating system. Trying to book an appointment with Honda now. See here:
heater problems
Heating system in '09 - fluctuates alot???
I can't see, even if my setting is on "fresh air" vs. "recirculate" that the air would go from hot to warm to cold depending on how fast the car is going. My Mazda3's heating system got a tad less hot/slower, but never started blowing COLD air. Must be a defect otherwise I'll be freezing this winter when our temps hit our usual -20 to -35 Celcius!
__________________
  #6 (permalink)
Old 11-03-2008, 02:15 PM
Rod2Rice's Avatar
Rod2Rice is a name known to allRod2Rice is a name known to allRod2Rice is a name known to allRod2Rice is a name known to allRod2Rice is a name known to allRod2Rice is a name known to all
I agree the fresh air setting may be it, but that should still bring in hot air. What happens is the blower pushes air across the heater core, so even at idle the engine coolant is still hot, and should bring in hot air. Unless there is a door/flap somewhere that is not set right and is pulling in air from the wrong spot. Something is definitely wrong though for sure so get that Fit into the dealer.
__________________
08 Sport AT BOM...JVC/XM/HD Radio/Infinity Kappas/Basslink/tint/alarm/remote start/HFP muffler/K&N drop-in/Progress RSB/16x7 5Zigen FN01R-C/Yokohama AVID H4S/LED tails
  #7 (permalink)
Old 11-03-2008, 02:19 PM
Booked tomorrow at 2h30 PM. More people are thinking it's a coolant issue so I'll let everyone know what the final issue/resolution is when I bring it in....
Quote:
__________________
  #8 (permalink)
Old 11-03-2008, 02:22 PM
Rod2Rice's Avatar
If its a coolant issue thats not good at all either. it could be creating hot spots in the engine which is a much bigger deal then just a bad blend door or something that I was thinking of. Low coolant can cause the same issue too, but it would have to be significantly low.
__________________
  #9 (permalink)
Old 11-03-2008, 02:27 PM
Oh oh.... great, now paranoid and worried! Well, not much I can do until the Honda techs look at it tomorrow.
__________________
  #10 (permalink)
Old 11-03-2008, 02:36 PM
Interstate526's Avatar
Interstate526 is a jewel in the roughInterstate526 is a jewel in the roughInterstate526 is a jewel in the rough
I wish you luck. Hopefully it's nothing too serious. I don't really have any complaints about the heating...although i don't like how the defroster has to be a/c.
  #11 (permalink)
Old 11-04-2008, 12:17 AM
polaski's Avatar
polaski is a name known to allpolaski is a name known to allpolaski is a name known to allpolaski is a name known to allpolaski is a name known to allpolaski is a name known to all
When the temp was below 0 deg F (what is that, approx -16C?), the civic wouldn't - couldn't - keep warm at idle. The block was too small, the motor wasn't burning enough fuel, and the heater was sucking enough heat out to close the T-stat. The temp needle would go down slowly and in about 10 minutes it would read C, there's no more heat and I had to shut off the fan. That, or recirc with the AC on, that would prolong the cooling effect but couldn't always prevent it.
We'll see about the fit. Smaller motor, uh oh.
Good luck figuring it out, it really shouldn't cut out heat as soon as you stop. The engine block does hold some heat in it!
__________________
08 VBP L15A1 MT stock
-sold- 96 EJ8 4dr, y8 i/h/e MT
  #12 (permalink)
Old 11-04-2008, 12:29 AM
bdrake's Avatar
bdrake has a spectacular aura aboutbdrake has a spectacular aura about
Quote:
Originally Posted by accordguyintake View Post
i think it might be because ...
Hey, Jason, how the hell would we know anything about the heating system? We live in Southern California! Just playing with you, friend!
I did however, live in northwestern Minnesota for two years. You haven't tested a heating system until you live in that kind of climate.
--Barry
  #13 (permalink)
Old 11-04-2008, 12:49 AM
haha yeah this is a conclusion from like 1 cold morning... the only time my car was cold.. does anyone else think the Fit stays warm alot? like cali-weather people
__________________
  #14 (permalink)
Old 11-04-2008, 01:05 AM
m-man@sbcglobal.net is on a distinguished road
when you are at a stop, the engine is idling, and the water pump is moving a lot less water around, as well as the engine is not making as much heat, it is normal to feel a slight difference, but it shouldn't go cold... even with it being that cold outside,
..interesting....not sure about that, i would have to go with what was said above, that the engine is just so small, i cannot compete with that kind of extreame temperature outside,
in that kind of temperature, i would keep the air on recirculate.
__________________
Vtec Light___A/C mod__HID's___Megan Axle Back
Zeta Dead Pedal___Yellow Indepent Fog Lights
Progress RSB
Best MPG so far - 42.4
  #15 (permalink)
Old 11-04-2008, 05:30 PM
Problem (maybe) resolved!
Ok, just got back from 2 hours sitting at the Honda dealership. I explained my exact issue with the heating system. They ended up "bleeding" the block heater. Exact words on my invoice are:
OPS10 BLEED THE SYSTEM ALL OK
4ITECH 1.20
,,,,,4191 no heat repaired b.h added new a/f
So, end result was an issue with my freaken block heater! For back story, the first remote starter they installed ended up being defective and I went 5 DAYS without my car (driving an '09 LX loaner) while they ordered/installed a second unit. Not having much luck with darn accessories!
Small consolation that it was NOT a problem with the car itself or the coolant system...phew! Can't test today since it is freakishly hot around here and will be so for the rest of the week. I'll report back if the problem is REALLY fixed once we get back to normal temps around here...
__________________
  #16 (permalink)
Old 11-04-2008, 06:30 PM
CrystalFiveMT's Avatar
CrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to beholdCrystalFiveMT is a splendid one to behold
Wow. You're here too?
  #17 (permalink)
Old 11-04-2008, 06:38 PM
Dang! My one refuge...
Quote:
__________________
  #18 (permalink)
Old 11-04-2008, 06:40 PM
nodrogkam's Avatar
nodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud ofnodrogkam has much to be proud of
When i drove my Fit in about 30 degree F weather, the temps would fluctuate. When idle the temp would drop - regardless of fan speed/fresh/circulate. It would get nice and toasty if I can keep the speed up.
__________________
Name's Gordon
  #19 (permalink)
Old 11-05-2008, 01:47 PM
More thorough explanation to heating issue/resolution
Doing some googling since now my curiosity has been peaked as to how my heating issue was linked to my block heater. Most 'block' heaters consist of small electrical heating elements mounted into a replacement 'frost plug' installed on the engine block. The heating element reaches into the cooling jacket surrounding the cylinders so that it is directly immersed in the coolant full-time, whether the unit is ever plugged in or not. When the block heater is plugged in, the element begins to heat the coolant. Since warm coolant rises, this creates some movement of the coolant to warm the whole block/head.
Found installation instructions here: http://www.jayhondaaccessories.com/Accessory%20Installation/2007/Fit/Engine%20Block%20Heater.pdf
They have to drain the coolant out of the radiator for installation. They then, obviously, refill the system with recommended coolant after the block heater is installed. Quote "Follow the instructions described in the service manual to fill and bleed the cooling system. Check the coolant reservoir for correct level and check the cooling system for signs of leakage. Repair as necessary."
Evidently what happened in my case was that the coolant was not properly refilled, hence impacting my car's heating system. Makes sense NOW and M4psycho hit the nail on the head when he offered: "It looks like this is a common issue if there is air in your coolant system/not enough coolant fluid. This prevents good circulation while you're idling 'cause either air is blocking the way or there's not enough fluid to flow through the heater core (when you're idling). This isn't a problem when you're moving because everything is forced through quite nicely. To remedy this you can bleed out the cooling line while topping it off while the car is idling. (Open the rad cap, idle the car for 5-10 minutes and keep topping up the rad fluid until it doesn't drop anymore)."
txmatt offered: "Apparently they thought it was somehow related to the coolant/cooling system since they attempted to bleed it and added antifreeze (a/f). I'm guessing the block heater heats the coolant in the block and they likely drained all or part of the coolant when they originally installed it and didn't get the system fully bled when they refilled the coolant/antifreeze."
You guys are GOOD!
__________________
  #20 (permalink)
Old 11-05-2008, 02:50 PM
Scratch&Dent is an unknown quantity at this point
Quote:
I have found a partial workaround: Leave the fan on 0, but turn the dial to defroster and set the lever to fresh air. Anytime you're moving, hot air will move up to the windshield, without turning on the A/C compressor.
__________________
Best tank: 518.1 miles, 47 MPG -- Best commute: 50.3 in, 45 out
'07 NHBP Sport AT
Previous owner's mods: Tint front and back, Mugen visors
My mods: Floor mats, Skunk2 50mm catback, T1R carbon fiber intake, T1R hood damper, T1R response header, independent fog lights, bronze 15x6.5 Konig Heliums in 195/55-15 Kumho Ecsta ASX's, Blitz throttle controller
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
