A 1 service- is it just oil & filter change?
Old 11-19-2008, 11:07 PM
shudderbug's Avatar
My 2007 Fit has 16000 miles on it. The LED indicates it needs "A 1" service.
The dealer says that "A 1" means: oil and filter change, tire rotation and brake inspection, for a total of $81.00.
I asked them what would the LED indicate if the car only needed an oil and filter change, and I was told it would then just register an "A."
Is this correct? or is "A 1" the minimum service?
Also, do any of you good people have (or do you know where I can locate) a list of the services that are required for some of the more common service codes, for example, "A 1," "A 2," "B 1," "B 2," etc.
Thank you.
Old 11-20-2008, 12:38 AM
Kishore's Avatar
Maintenance Main Symbol
A: Replace engine oil
Maintenenace Sub-Symbol
1: Rotate tires, inspect for wear and adjust pressure.
Old 11-20-2008, 12:48 AM
kylerwho's Avatar
spoon fed
look in your owners manual. it lists all the maintenence minders there. it also tells you how to shut them off.
Old 11-20-2008, 01:25 AM
shudderbug's Avatar
Thanks for the information. I appreciate it.
Old 01-02-2009, 03:37 PM
SFactor2's Avatar
Location: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
why would anybody READ THE MANUAL for the second biggest investment they will ever make (next to your house), for THE BIGGEST KILLER in NA (2500ish death machine), the thing that transports your friends/family.....why would any sane person waste just a few minutes to read the manual:r otfl:
Old 01-02-2009, 06:55 PM
trancedsailor's Avatar
whoa dude, relax ^
I don't read manuals for videogames unless I'm bored as hell.
I skimmed through the Fit manual and stopped a few times, but most things you figure out over time.
Old 01-02-2009, 07:42 PM
i've yet to read the FitS's manuals cover to cover... i check periodically
for maintenance requirements but that's all. i use it as a guide mostly to
keep my car within warranty and under good working order, not as an
owner's how to manual.
Old 01-02-2009, 09:16 PM
redrumm's Avatar
yup thats what an A1 is. oil change and tire rotation
its pointless IMO. i just get the oil changed and thats it.
if you want more info next time you go to service ask for a brochure because they should have them, we do, and it will tell you how much each one cost's and what they do.
to be honest if you know there is nothing wrong with your car just keep getting an oil change
Old 01-02-2009, 09:21 PM
redrumm's Avatar
because it tells you thinks you might want to know or did not know. why not read your cars manual?
now ive wasted of few min. of my life trying to tell you, your a jackass
Old 01-03-2009, 02:20 AM
doctordoom's Avatar
Supervillain
dammmmn they wanted $81 for oil/filter change and a quick inspection? holy rip-off!
Old 02-09-2009, 04:04 AM
busdude's Avatar
Is what's worse is that even if you go by what they recommend, they dont do all the work. Nothing ever gets said in there about an alignment. a $200 inspection and oil change is what you get out of the deal...
Old 02-09-2009, 09:19 AM
spreadhead's Avatar
You don't much understand the concept of that irony thing, do you?:rot fl:
Old 02-09-2009, 10:06 PM
E = Mc2's Avatar
No kidding! My dealership charges $25... whoops! $26.91 after tax for the same service!
Took it in a couple of weeks ago and got the 'B' service (oil change, tire rotation, all fluids, inspect brakes and exhaust, etc., etc. and so forth), and they, again, charged the same as the regular oil change.
Old 03-02-2009, 09:20 PM
FITTECH's Avatar
HA a B service in canada involves a brake service too all for $180. To bad I dont have to pay that I am a honda tech lol. I need every penny I can get since I make dink for pay. If I had to pay for service I would not be able to drive lol.
Old 03-02-2009, 09:28 PM
FITTECH's Avatar
A oil change is a oil change, your car has what 20 000km I dont know in miles lol. Does your car stop, make any noise, any lights on the dash besides the stupid wrench. then why you need a brake inspection. if anything get them serviced. only thing is I would recommend to try and do a tire rotation every 10-15 000km in miles I dont know. Where u live in a none harsh climate brake service should be done maybe once a year, harsh climate I recommend twice a year.
Old 03-02-2009, 09:29 PM
FITTECH's Avatar
whoa dude, relax ^
I call it the dummy manual....
Old 05-02-2010, 04:39 PM
w1ndex's Avatar
I would check my manual, but well, someone stole it... Don't know why, but it's not in my glovebox. Every other book is, just not it.
accolay
11-14-2016 07:51 PM
g fit
05-06-2014 03:47 PM
workin9classhero
12-10-2013 09:12 AM
white_FIT2012
09-14-2012 06:12 PM
rhecht
08-24-2009 06:21 AM
Quick Reply: A 1 service- is it just oil & filter change?
