Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 08-03-2009, 01:14 PM
DarkStorm is an unknown quantity at this point
Check Engine Light on for Low Oil?
My 08 Fit has 17,000 miles on it. Last night I left the car idling for a while to heat the car up to cure some fiberglass. When I came back to the car, the check engine light was on and the mileage display was showing the oil life at 15%. It had been showing miles when I left the car. When I changed the display back to miles, the check engine light went away. So my question is: does 15% oil life cause the check engine light to come on? I usually replace the oil at 20% life so I have not encountered this before. If it truly was a real check engine light, then I will be upset cause it went away and I have nothing to show the dealer.
Sponsored Links
  #2 (permalink)
Old 08-03-2009, 01:30 PM
onemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to liveonemiglandicho relies on Rep Points to live
If I may ask, what was the icon that you were seeing? Was it like a wrench? I'm pretty sure that it was just reminding you that you should get an oil change with other things that Honda recommends. Once the MM tells you you're at 15% that service light or wrench light comes on and will disappear if you change the display to mileage, gas mileage etc. The service light will remain no matter what you do when it hits 0% oil life I think. Read your Owner's Manual, it will give you a more thorough explanation. Hope this helps.
  #3 (permalink)
Old 08-03-2009, 02:31 PM
Stevens24's Avatar
Stevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to liveStevens24 relies on Rep Points to live
The check engine light is the outline of the engine. If you saw that, the next questionis were you working on the car? In some instances disconnecting certain plugs will trip the light, when you plug it back in the ECU will cycle,see that the connection has been restored and turn off the light. When i changed my hazard swith i tripped the light and then it reset the next time the vehicle was started.
  #4 (permalink)
Old 08-03-2009, 04:13 PM
Doug Just Doug's Avatar
Doug Just Doug is an unknown quantity at this point
As the two above. Plus, don't confuse oil level with oil life. If you're wondering about oil level, check the dipstick.
__________________
Do you also have a fit over motorcycles? Visit my stupid little website!
  #5 (permalink)
Old 08-03-2009, 05:35 PM
Interstate526's Avatar
Interstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to liveInterstate526 relies on Rep Points to live
as they said, if it's a wrench, don't worry. Just change the oil. If it's an engine, then have the code read, or take it in.
__________________
-Ryan
Reply
Tags
check, civic, damage, engine, fit, honda, light, lights, low, motor, oil, reset, service, worry, worrying
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Engine light after new intake... wilbur 2nd Generation (GE 08-present) 8 06-28-2009 12:01 AM
Check Engine light came on today!! Skytraveler Fit Trix General Discussions 1 02-14-2009 12:46 PM
Check engine light after... EYEoneFIT Fit Exhaust Systems 2 07-27-2007 06:09 PM
2001 Civic EX check engine light acidic@tokyo.com Other Car Related Discussions 0 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
