Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-08-2009, 07:43 AM
jazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awardsjazz_do_it should get some awards
coilover question . .
I heard from a mechanic that each time you lower your car, you need an alignment . .
Does this rule also apply if you have coilovers?
I don't know much about coilovers so i posted this, kindly help me.
Thank you. .
Sponsored Links
  #2 (permalink)
Old 09-08-2009, 09:13 AM
CuTeBoi's Avatar
CuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to live
Is the car lowered with the coil overs?
__________________
Got Speed?
  #3 (permalink)
Old 09-08-2009, 09:26 AM
not yet, i am planning to buy one . .
I am currently on H&R springs . .
  #4 (permalink)
Old 09-08-2009, 09:46 AM
Daemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to liveDaemione relies on Rep Points to live
Yup. Any time you change ride height, or change just about anything on the suspension, you need an alignment.
  #5 (permalink)
Old 09-08-2009, 10:00 AM
so if i buy a coilover, i need to get an alignment each time i adjust the ride height?
Thank you very much . .
  #6 (permalink)
Old 09-08-2009, 10:37 AM
CuTeBoi's Avatar
you answered your own question. If you change ride height, you "should" realign for that height...
You answered your question in the OP
__________________
Got Speed?
  #7 (permalink)
Old 09-08-2009, 10:54 AM
YellowStarS2000's Avatar
YellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to liveYellowStarS2000 relies on Rep Points to live
Just FYI, when you lower the car your toe is changed. This is the single most vital spec that causes premature / uneven tirewear.
  #8 (permalink)
Old 09-08-2009, 11:48 AM
when i got my lowering spring installed, i did not get an alignment.
I got it aligned after a couple of months when i noticed uneven wear, can that cause any damage to my suspension?
  #9 (permalink)
Old 09-08-2009, 06:32 PM
DatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to liveDatFIT relies on Rep Points to live
No... but lowers the lifetime of your tires.
Reply
Tags
adjust, alignment, coilover, coilovers
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
T1r bmax coilover question jdm_gd Fit Suspension & Brake Modifications 8 02-11-2009 03:01 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
