Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > 1st Generation (GD 01-08)
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-24-2009, 12:39 PM
inxsole is an unknown quantity at this point
Rear Garnish question
does anybody know how to remove the rear garnish that holds the H emblem on the trunk on a GD because I'm planning remove the emblem. I've seen the mod section of the forum and couldn't find a related thread to this.
Sponsored Links
  #2 (permalink)
Old 10-24-2009, 12:59 PM
DreaMv's Avatar
DreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to liveDreaMv relies on Rep Points to live
if you want remove the emblem, look here.
JDM red badge DIY *warning* lots of pics
its a few pics down
Quote:
Originally Posted by NIGHTHAWKSI View Post
to do the rear badge, look between the hatch and opening handle you can see 2 white pins sticking down (not in my pic) but they are in that area. break them off using a flat headed screw driver and tapping on it with a hammer. it will not take much force to break them. once both are broken, the badge will pretty much fall off
anddd you can buy the mugen replica rear garnish i guess
__________________
- NHBP GD3 -
  #3 (permalink)
Old 10-24-2009, 01:31 PM
I've read that DIY thread before, but i'm actually asking how to completely remove that whole garnish piece.
  #4 (permalink)
Old 10-24-2009, 01:40 PM
JDMchris.com's Avatar
I run THIS
JDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to live
Send a message via AIM to JDMchris.com
you pop off the liner on the inside and theres some bolts and clips then it just pops off.
__________________
KRAFTWERKS Kit Owner #1
www.Kraftwerksusa.com BOOOOOST!!!
www.skunk2.com Best Coilovers!!!
www.Robearracing.com Rob is the Man!!!
www.prmracing.com Best intake on the market!!!!
www.teammfactory.com LSD and Final Gears!!!!
EPIC BUILD
IHFP!
JDMchris.com's Sig Specific Sub-Forum
  #5 (permalink)
Old 10-24-2009, 02:50 PM
can you show me what you're talking about with pictures?
  #6 (permalink)
Old 10-24-2009, 03:26 PM
I run THIS
Remove #20 clips then pull off #1 panel and that will give you access to the garnish bolts/clips
I think theres 2 bolts and 4 clips, then it comes right out.
__________________
EPIC BUILD
IHFP!
  #7 (permalink)
Old 10-24-2009, 03:57 PM
score04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to live
like jdmchris said, about 2 bolts and a bunch of clips, a little muscle and it will pop right off. to get the interior trim piece off, there are two push pins on the under side and then take the handle part off at pry the piece off with some muscle.
__________________
  #8 (permalink)
Old 10-24-2009, 07:49 PM
I got those two pins on the underside of the interior (one actually broke for some reason).
But the problem now is the handle I dont want to break that so I'll need more help on this one.
  #9 (permalink)
Old 10-25-2009, 11:33 PM
take two screwdrivers and youll notice two tabs on the handle, pry those towards you. you wont break them, the handle will just fall out then
__________________
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
rear trunk garnish beangrower 2nd Generation (GE 08-present) 8 09-30-2009 01:43 PM
To all you suspension have a question about the rear suspension of the 07-08 fit hondafitblue Fit Suspension & Brake Modifications 4 06-17-2009 09:19 PM
FS: JDM Mugen Rear tail gate garnish heymikesays SoCal Classifieds 2 03-11-2009 02:49 AM
Where can I find this rear garnish? trancedsailor Fit Exterior Modifications & JDM Styling 9 10-12-2008 01:25 PM
SImple How to guide on suspension ghostfit Fit Suspension & Brake Modifications 4 02-09-2008 04:07 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
