Automatic Transmission Filter - Unofficial Honda FIT Forums
Reply
LinkBack Thread Tools Search this Thread
Old 04-16-2010, 06:41 PM
bluecivic107's Avatar
I just changed the ATF @ 30,000 miles with HONDA ATF-Z1 2.5 US QTS. was wondering if I should replaced the Transmission oil filter as well....
What do you guys recommend???
Thanks in advance!!!
Old 04-17-2010, 02:49 AM
Seeing as how the filter is outside the trans and it isn't all that expensive, I would consider it cheap insurance to change it with the fluid...
Reply
Transmission Fluid Level kaede1337 2nd Generation (GE 08-13) 5 07-31-2016 06:22 PM
ATF oops JBox Fit DIY: Repair & Maintenance 0 05-10-2015 04:56 PM
Full ATF DIY Flush GC617289 Fit DIY: Repair & Maintenance 7 07-07-2012 12:25 PM
ATF drain plug SK Ninja Fit DIY: Repair & Maintenance 14 01-04-2009 03:38 PM
Honda ATF Fluid or Valvoline Maxlife Dexron III Fluid DaviT Other Car Related Discussions 11 05-04-2005 05:44 PM
Tags
2008, 2009, atf, auto, automatic, change, diy, filter, fit, fluid, forum, honda, oil, tools, transmission, trnsmition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
