Jazz DSi with 4 plugs
Old 03-19-2011, 03:20 AM
EXT's Avatar
EXT
EXT is offline
Angry Jazz DSi with 4 plugs
hi every one,i got 06 jazz 105K on the clock,the car was jerking some time
in high gear especial low speed drive, so i found out like this:
ok here is my findings
i disconnect front ones with back ones connected than drove,jazzy jerked as normal.than i let it idle and disconnect one by one
and connect it back.each time when i disconnect car misfire.but when all 4 are connected it idle fine.
only when i drove it jerk. fouled plugs.................?? what u guys think?
car is out of warranty. honda dealer are 3 hours drive from my place.
i did read othe posts connecting to this problem...
just your thoughts
thanks
Old 03-21-2011, 06:10 AM
EXT's Avatar
EXT
EXT is offline
seems no one got DSi ver jazz..............
Old 03-21-2011, 10:16 AM
Hootie's Avatar
Not many people from what I've seen here have the i-DSI engine since the forum consists of mostly North American (US and Canada) which only get their Fit/Jazz with the VTEC L-series. There are some members with i-DSI engines here though but for every 1 i-DSI member there are like 2 or maybe 3 VTEC members.
Never the less, is your car showing any check engine codes or is the engine light flashing during engine misfire/hesitation?
Does this happen at a specific engine RPM or throughout the engine's RPM range? Also, what kind of fuel are you using (brand and octane/RON/MON rating)?
From what I've read, the i-DSI is an 8 spark plug engine and only uses 4 when the engine is not under a heavy load. Since you've already tested half the plugs on the engine (and assuming that all 8 plugs are the same length), label them and swap them over to the opposite side for the untested plugs. Test again and see if there is any difference.
Old 03-21-2011, 12:27 PM
EXT's Avatar
EXT
EXT is offline
no engine light flushing,using shell vpower and techron unleded from different garages.car never been service by honda dealer after
70k and now is 100k.i read some where that most after mark machanics dont know
that car has 8 plugs. they may be only changed front ones.
car only hesitate when back ones are connected..........
and in low rav after proceding from a robot or stop sign.not on high way with high speed.
Old 03-23-2011, 10:24 AM
EXT's Avatar
EXT
EXT is offline
OMG.......i found 2 of coils bad.and i think is the heat that cause that.
thekerr
12-19-2014 11:19 PM
porkie
07-07-2009 02:49 PM
thaijim
02-29-2008 02:46 PM
Gordio
12-08-2006 09:47 AM
pappiccio
12-09-2005 01:28 PM
Quick Reply: Jazz DSi with 4 plugs
