Aircon dead!!!
Aircon dead!!!
Hi. I live in Zimbabwe and right now the weather is burning the skin right of your bones!!
As I was driving yesterday, with the cool breeze of the AC whistling past my ears, suddenly, the breeze turned it into a hot wall of hellish fire! For no reason I cant get cold air!!!
The A/C light on the dashboard still lights up and I even hear the fans kick in when I press the button. This is leading me to think that maybe its something wrong with the refrigeration side of things because there is usually that click that comes every minute or so when you have the AC on but its now gone. And when I switch on the AC the rev meter increases slightly for about 3 seconds instead of the usual decrease in revs meaning that the computer side is fine as the car is compensating for the impending load of the A/C system.
I had a quick test for gas yesterday and the meter read fine.
So do any of you have any idea of what could be going on with the A/C because I'm hoping its not a major problem as I can only access a mechanic in about a weeks time!
Thank you.
Thank you.
Thank you.
Thank you.
Ok..I'll have to check that tomorrow morning because Im just about to sleep...is it particularly hard to find or is one of those things you can't just miss?
It's simple open the glove box and press and hold the edges inwards and gently pull it outwards. You'll see the filter their. And rule if thumb if it is white or cream its ok. If its brown or darker that means change it as soon as you can.
lief101
04-22-2017 05:34 PM
