Factory Alarm Horn does not sound
I have been lurking around here for a while, and unfortunately my first post must be question =(
I have searched and search and could not find an answer to this:
So the alarm on my 07 seems to have gone crazy.
When I double press the lock button, the horn no longer sounds.
When I double lock, randomly it may sound the horn.
Opening the door after removing the key, the red light on the steering column lights up solid for a few seconds. I have checked every single fuse and they all look ok. The panic button works as well. I found a grey module with a green connector under the dash, and after unplugging it, the alarm appears to work normally. Double pressing lock will always make the horn sound, however, when I unlock the car from inside after arming the alarm, nothing happens. I have driven around with the module unplugged for around 5 minutes and nothing seems wrong with the car.
Please help!
EDIT: NVM - Continued here
https://www.fitfreak.net/forums/1st-...-not-beep.html
Please help!
Well if anyone is interested,
here is the link to the pdf file with the OEM security system manual
http://www.wedophones.com/Manuals/Ho...nformation.pdf
as per page 7, the car was put into valet mode
I've had the same problem. I had to disconnect the wire going to the hood. Its under the hood latch. The car is now arming properly.
teaboxx
08-20-2013 03:14 AM
GaryJaz
05-04-2005 04:44 PM
