Error Code P2A00 Oxygen Sensor
Hello Gentleman,
I have a 2008 Honda Fit, sport model, with about 25,000 miles.
A few days ago the check engine light came on.
Code reader says: "P2A00 O2 sensor circuit range performance bank 1 sensor 1"
I assume there is a problem with the oxygen sensor. I believe this model had 2 oxygen sensors?
Which sensor is the problem? I believe the problem is with the front sensor, the one before the catalytic converter?
Thank you for any information you may be able to provide.
Up to now I have had zero issues with the car.
My lower 02 Sensor went out this spring with 62K miles on the car, and the upper went within a week after changing the lower. I used OEM NTK sensors, but would probably order Nippondenso ones from amazon.com next time. I'm partial to Nipppondenso.
Jutboy
04-12-2024 11:51 AM
fitowner10
03-09-2019 09:02 PM
MTLian
04-10-2014 05:37 PM
