The bottom radiator hose cold and the top one hot
Hi All
I hope you guys can help I have a problem with a Honda Jazz/ Fit
The bottom radiator hose cold and the top one hot.
I can not see an signs of leaks and there is coolant in the radiator.
There has been no work carried out to the cooling system or I do not think is in the system.
The pipes look to be ok
Please can you give me some advice.
Thank you
Thank you
http://img23.imageshack.us/img23/3640/1001585s.jpg the lower hoes werer its connects to the block right be low the many on the right side if ur looking at ur car from the front facing it theres two bolts holding it
Are you having overheating/cooling issues? If not, don't worry about it.
The bottom hose stays cold if the thermostat is closed, and the thermostat stays closed until the engine reaches a certain temperature. There's simply no need for the thermostat to circulate coolant flow through the lower radiator hose if the engine temp is still below the threshold, it doesn't yet need that much cooling through the radiator.
It's not uncommon for the Fit's thermostat to remain closed sometimes - its tiny engine doesn't run that hot and the factory cooling system is more than sufficient.
If your car is overheating and you notice that the bottom hose never gets cold (meaning the thermostat never opens, even at overheating temperatures), then you probably need to replace the thermostat.
If you want to check that your thermostat is working, just drive the car on the freeway for 5-10 minutes then feel the lower radiator hose. Or just drive it really hard and then feel the hose. It should get hot when the engine gets hot enough for the thermostat to open up. The upper radiator hose will always get hot first.
Hi All
Thank you
Thank you
If the lower hose wasn't cooler than the top your engine will be cooked pretty soon.
That help?
If your water pump failed the car would overheat. What are your water temps? like someone else mentioned the lower hose should be cooler because the coolent had passed through the radiator.
I actually really dont understand what the issues is? what made you worried about this to check it?
Yea, what issues are you having? There's nothing wrong with the lower hose being cold after driving, unless you're having overheating issues.
I read this entire thread again and do not see the point of the question. We have a radiator that takes in hot coolant, cools it down, and supplies it cooler out of the other end. That is what a radiator does.
The top hose is HOT and looking like its bulging or over pressurized.
I have removed the hose at the radiator and ran the engine and now water came out.
I am thinking the pump as failed now.
My radiator is not blocked either.
I have removed the bottom hose and connected a hose pipe to it and flushed water through it.
What is my next step please?.
Ok then.
The thermostat is about a fifth of the price of a pump so I would go for that first.
The pump looks like a lot more work.
I don't know which Fit you have, Year model etc....but this is fairly common set up.
Go to Bernardi Honda. Punch in your info and it should put you in the ball park.
in the pic below the pump is number 1 and the thermostat is number 4 Both parts would cost you around 150$ Canadian money with the seals and taxes.
Honda Car Parts / Choose by Model / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda
Found this page from the UK.
150 of your pounds for both.
