Positive battery terminal attachment very loose
Hello,
I just recently replaced my Yuasa 151r with a Costco 51r battery and I've been very satisfied. However, I had forgotten to slip the little black plastic cap thingie back on one of the brackets that hold down the battery so after work I popped my hood and tugged lightly on the positive and lifted the clip right off the terminal! So I drove home with basically little to no battery and once arrived I got out my 10mm socket and wrench and removed the negative and replaced both clips.
The problem is that no matter how hard I tighten the bolt on the positive terminal, the metal ring is just sitting on the terminal and I can easily pull the clip right off with no effort! However, the negative terminal is on there nice and tight. I'm afraid the clip on the positive terminal could come off by simply driving, or by the weight of the clip of a booster cable. How can I attach the terminal more securely?
Get a battery post shim:
Lynx/Battery post shim (07769) | | AutoZone.com
Autozone or regular auto stores should carry these and they're cheap.
Do not shove a random piece of metal in (bolt, penny, etc.). You could cut or make a shim as long as it wraps all the way around the post.
Here's a link for your reading pleasure:
https://www.fitfreak.net/forums/1st-...too-small.html
Search works too. Just take your time...
Thanks for the help! I noticed my clips are greased, I guess to prevent corrosion. Should i grease the shim? Will vaseline do, to prevent rust/corrosion? Unfortunately, it seems a shim will me hard to get a kid of in my area.
Battery Post Shims (Package of 2)
make: Schumacher Electric
Model: BAF-2
I did the same last week. Installed shims on the +ve and -ve terminal
Vaseline will prevent corrosion
Thanks man! I haven't been able to find the product at Canadian tire so I was gonna try napa next. My negative terminal is tight as can be and won't budge, it's my positive that's the culprit, I wonder why. Edit: I see that the Yuasa has a small neg terminal and a fat positive terminal; I think my 51r has two medium sized posts which must account for the tight neg and loose pos.
Shims come in a pack of 2 and I am definate 3/4/5 years down when I have to change the battery I will not find the shim in my shead, so the best place was to use on the negative terminal (its better fitting now)
My battery is also from costco 51r. The negative termial was snug enough.
On the Topic that Subie posted, this was my contribution:
https://www.fitfreak.net/forums/1st-...ml#post1086123
I like it because it complements my lifestyle.
BTW, I replaced the battery on my CRV a couple months ago, and had to use my own advice.
The important thing to remember is, the improvised shim should only go half-way around, so that the terminal clamp and post have a good contact area!
Hello,
one or two layers of .050" should do it.
THE SAGA CONTINUES...
called Canadian Tire, called Wallmart, they don't carry it, called frikkin' Napa auto parts, they still don't have it. All those guys want me to change the terminals instead of putting a shim in there. I'll probably have to order the stupid part from the internet. Jesus H Christ! A stupid shim!
How would one go about changing battery terminal connectors anyway?
If your really concerned and you want a little piece of mind til you can get the proper piece. I've used aluminum foil on a crx battery post of mine for 2 yrs with no issue. Is a little rigged but it works. I covered the post in a little piece of foil and put the terminal end over it, tightened it down and trimmed off the rest.
Stop stressing and use my beer-can method.
Besides being fun to obtain, the can's material is easy to cut. Done correctly, you won't even see that it is there (so, no need to use name-brand beers in the performance of the "fix").
Hello,
Here is your fix, less than $3 bucks at most major part stores
ChuckDustin
03-29-2019 09:11 PM
fit newb
05-31-2015 11:04 PM
piclistguy@yahoo.com
05-04-2005 11:16 AM
