honda jazz 2002 abs light. - Unofficial Honda FIT Forums
Reply
Thread Tools Search this Thread
Old 09-21-2013, 09:07 AM
needed to do gearbox bearings and clutch,drivers side driveshaft fix solid in hub. ABS light working ok before started work.replace driveshaft and hub. abs light still working OK. noisey bearing so replace bearing with brown seal towards sensor,brown seal as a magnet inside bearing. replace everything, abs light went off,until i applied brakes.brakes went hard and noisy,abs light stay on .,brakes returned to normal operation.(abs disengaged ). had honda check abs faults sensor not reading when wheels are turning. Sent off for another sensor,just incase i damage previous sensor when doing bearings. install new sensor.abs light went off when moving off.applied little pressure to brakes ,Brakes pedal hard to brake,noisey,just like before, then abs light came on and back to normal braking without abs system working. back to square again. got four new tyres fitted all around.all pressure correct.the drive shaft did come from 2008 jazz,not 2002.but i do not believe they alter the size of the outet drive shaft,causing sensor to rub against,unless you know different. could the bearing be faulty,not honda make.what else could i try.
Old 09-26-2013, 08:56 AM
was a defective bearing,install new bearing everything working as normal.no more abs light staying on
Reply
Scan tool that reads Fit ABS codes? phoenity General Fit Talk 7 10-20-2016 06:39 PM
ABS Skid Light ON jdDC 2nd Generation (GE 08-13) 4 12-30-2015 03:52 PM
Emergency Wheel Bearing Question tshiv 1st Generation (GD 01-08) 5 05-01-2015 03:56 AM
ABS and E-Brake Warning Lights stay on continuously gsarmedic Fit DIY: Repair & Maintenance 6 11-13-2013 11:05 PM
Question about Brakes and master cylinder Santiad 2nd Generation (GE 08-13) 1 03-19-2013 04:01 AM
Tags
2002, abs, fit, honda, hondafit, jazz, light, position, replace, sensor, showing, size, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
