Automatic shifter light
Old 05-19-2014, 11:51 PM
spreadhead's Avatar
Is the console shifter selector illuminated (does the gear selection light up)? Mine is not lit. Did it burn out or was it never lit. I think it was, but I could be wrong. Want to know before I remove the console.
Old 05-20-2014, 12:17 AM
ikutoisahobo's Avatar
It is lit, yes. Only when the headlights are turned on though.
Old 05-20-2014, 12:36 AM
spreadhead's Avatar
Thanks, I guess my bulb is burned out. Anyone know the bulb number?
Old 05-20-2014, 01:07 AM
Not sure, I tried looking around. If you're gonna open up the console you might as well just pull the old bulb out and see what it is,
Old 05-20-2014, 09:10 AM
spreadhead's Avatar
Would like to have the new one on hand to save time. Remove console, replace bulb, reinstall console without having to run to town, and possibly wait for a hard to find bulb.
Old 05-21-2014, 05:30 PM
Scholzpdx's Avatar
I've got an 07 Sport auto with 143k. Mine doesn't light up at all. If someone finds a part number on the light, please post it here.
Old 05-22-2014, 01:16 AM
spreadhead's Avatar
Don't know the bulb number and don't have it with me at the moment, but my stealership had it in stock for $3.
Old 12-03-2016, 05:39 PM
frank438's Avatar
How do you open up the console to replace the bulb? Ours in our 2008 Fit just went out too, and I don't want to dismantle the whole console just to change one tiny lightbulb. Also, anyone know which fuse controls the bulb? Maybe it's just a blown fuse, which would be much easier to change than the bulb.
Old 12-03-2016, 09:39 PM
doctor J's Avatar
The console has to be removed to get access to the bulb; it doesn't have a separate fuse
Old 12-03-2016, 10:04 PM
frank438's Avatar
Dang, I was afraid if that. Would be too easy to make it accessible...
Can the grey oval shaped piece around the shifter itself (has the P, R, N, D, D1, etc. in it too) be removed or at least loosened? I would think logically this should come off far enough to change the bulb...
Old 12-04-2016, 10:44 PM
Hootie's Avatar
The center console is easy to remove. 2 push clips, 2 screws, the auxiliary & accessory socket connectors and MAYBE the parking brake cover/lid if I recall correctly then it tilts up and out the way.
Old 12-04-2016, 11:33 PM
frank438's Avatar
Thank you! I will have to try this next weekend if I get time.
Old 11-27-2017, 03:38 PM
utsug's Avatar
anybody knows what is part number for this bulb? Thanks.
I found the part. there are two part numbers P/N 35505-692-003 and P/N 35505-TA5-A51. This is for GE8, not sure if its the same for GD.
http://www.bernardiparts.com/Honda/Parts-List.aspx
Ozray
06-14-2019 02:19 AM
kbh
12-07-2013 03:00 PM
alanchan
03-28-2013 02:57 PM
Black01
01-08-2011 10:56 PM
swingbyte
03-31-2010 08:24 AM
Quick Reply: Automatic shifter light
