GD Sideskirt Mounting
I've been looking to reuse my GD sideskirt that got ripped off by the curb, the only broken part of the skirt is the back brackets that hold the clips.
^ that piece.
I've got 3 out of I believe 8(?) haven't looked at the skirt in a while. I was wondering if it would just hold with the bottom black mount things,
I haven't seen the skirt in a while so I don't know its condition, it's somewhere in the garage.
My question is will it hold with just the bottom black brackets? Without looking too funky and out of place?
I'm sure you guys with the body kits know.
^ that piece.
There are several clips that side into the side skirt which allow you to clip the skirt into the chassis of the vehicle. Those riveted plastic brackets in the side skirt itself just uses the black plastic push clip to clip under the car.
I am looking at putting side skirts on a base model and am only using the ones underneath, in the wheel well and double sided tape. I am 99% sure this will line up. Interesting fact is that i have to drill 4 10mm holes under the car for the bottom expanding clips to go into as the base does not have them under the car. ( I looked)
I am also going to go forward with a rep Mugen Bumper and remove my fresh real lip.
You should be able to remove and replace those clips as well. They should come out by grabbing them and rotating them about 45 degrees either left or right (its not specific). Transfer all your new/good clips onto the side skirt, pop it on, and call it a day.
My side skirt area on the car being base has no plug holes drilled for the clips. It would be a matter of putting tape on the edge very close to the top and on the plug clips on the skirt. I am hoping its enough because drilling 8 hole plugs is not happening. Hard to find oem skirts body colored to match. I am so close to my base to sport conversion after all these years. It paid off because of its cleanness to now swap lips and skirts all day
I have the clips for the 3 brackets that remain. I'll see if it holds with just three.
ikonmotorsports - FIT - HONDA - MAKES - Parts & Accessories <--- I was wondering if skirts like these would have a good fitment, in case my broken skirt doesn't properly mount. Also I need a rear lip since I'm missing that too. I'd replace the front lip too since it's banged up.
I found the entire lip/sideskirt kit for 160 bucks on eBay, but it said the application is using double sided tape, that made me get worried about fitment.
Since I don't have the push clips that go underneath the car to mount the sideskirt, I ordered these ones:
Let's see if it'll hold.
Amazon.com: 10mm 40 Pcs / Pack Push-type Nylon Bumper Fender Flare Fastener Rivet Clips 91503-SZ3-003 For Honda Accord Civic CR-V CRX Del Sol Element Fit Insight Odyssey Pilot Prelude Ridgeline S2000 Acura CL Integra MDX RDX RL RSX TL TSX: Automotive
Managed to get it on today. My skirt seems to be bent towards the center from the impact or whatever, and it doesn't sit evenly with the car. The rest of it looks pretty good, just a little droopy towards the rear (since no brackets) will post pics.
Certainly looks a lot better than no skirt. I think I'll have to repaint it though, but I'd probably be better off going to a junkyard and finding a used skirt.
