Wet Back Passenger Floorboards
Old 12-30-2016, 09:03 AM
KylelHunter's Avatar
Hello. I am looking to see if anyone could provide some info on why I could be having wet floorboards behind the passenger. It happened to me earlier this month and I figured I left the window open. I soaked up as much water as I could and dried it out. It just rained the other day and now it is soaked again, but I don't know if the rain was the cause. It is winter time and I don't know if running the heat would build up condensation on the ground. I saw something about the A/C line being possibly clogged or pinched but I don't know if that deals with heat too.
Also if it is because of rain, is there an easy way to determine where it is coming from? I want to try not to go to the dealer and spend a lot of $$$ if i can do it myself. Thank you!
Old 12-30-2016, 02:43 PM
doctor J's Avatar
If no water is present in spare tire well, the inner door plastic shields have to be removed, cleaned and re-glued.
If water is present, 2 tiny cracks below roof molding stripes should be sealed
BTW, any update on your older post about check engine light??
Old 12-30-2016, 04:01 PM
BurntZ's Avatar
yep, I'm guessing the plastic liners inside the rear doors have been compromised. They need to be taped/sealed back up by taking off the plastic inner door panel. The water is coming down the window and depositing on to your floor. Sorry.
Old 01-19-2017, 11:35 PM
Gage Hartwell's Avatar
i also had this issue along with pool of water in my spare wheel well. i was looking at where others were sayiing the issue was and, no luck. so the source of my problem is: when you lift up the hatch, theres a gap between the tail lights and the body. this is where the water was getting in. i sealed it with some glue and huzzah! no more leaks.
captainhowdy
04-05-2018 11:57 AM
noneterry
02-09-2015 10:56 AM
geepondy
03-30-2014 07:53 PM
Cyphron
01-15-2011 11:49 PM
Luichenwai
11-11-2008 10:32 AM
Quick Reply: Wet Back Passenger Floorboards
