07 Fit starter replacement
Old 01-17-2017, 01:27 PM
Sharkster's Avatar
Hey guys, I have a starter replacement question...
Should I remove the intake manifold for better access to the starter? Would it make the job go easier? I figured someone out there has replaced theirs, and I'm looking for the less stressful way to do it. I have a 2007 Fit Sport.
Thanks guys!!
Old 01-17-2017, 03:22 PM
BurntZ's Avatar
I can't provide you any info other than if you decide to get it done at a shop, Pep Boys quoted me $106 for the labor to install their ProStart model with lifetime warranty.
Old 01-18-2017, 06:35 PM
doctor J's Avatar
You will have to remove air cleaner housing to access 17 mm bolt; 14 mm bolt requires bend 14 mm wrench with cheater; removal of lower intake will give you better access to the connectors.
Old 01-19-2017, 07:49 AM
Sharkster's Avatar
Thanks for the info doctor J. That did look like the more reasonable way to go. I like to do my own work on my vehicles, and this is my first Honda. Figured better ask first than break something first.
PT Aleco
05-05-2021 12:35 AM
zenkimr_S
08-07-2020 06:34 PM
MyFitment
08-02-2020 03:29 PM
Rrff1954
08-26-2018 08:17 AM
mmdir2002@yahoo.co.uk
05-04-2005 11:16 AM
Quick Reply: 07 Fit starter replacement
