Quote:
Originally Posted by kennef
couple of quick questions -
#2: you make it sound like they do suspension development for a major OEM. do they, and for who?
#7: i'm assuming that the 7/6kg means 7 up front, 6 rear, which makes no sense for a FWD. but, you did mention that the stock valving will handle a +- 2kg range. with that in mind, i'd like to do something that more closely mimics the stock spring rates with a little extra rate in the back as it's aparent that the progress bar would be too light for the spring rates we're talking about here. would you be able to do something like that?
i'm assuming that KB specified their own valving. my question is who is the damper manufacturer and where is it made? for example, ohlins damper manufactured under licensing agreement in japan? bilstein, koni, etc?
i'm very interested in these because the price seems right. how are your coilovers holding up now? have they gotten any noisier?
lastly, price?
#2 - Kbee themselfs told me they OME shocks for Buddyclub. They make there own dampers. The body is built/assembled in Japan.
#7 - Yes general rule of thumb is +/- 2 Kgmm max. (any coilover system you go with, its juat a standard rule of thumb) Yes you can change out spring rates not a problem, to provide a closer feel to OEM springs of the car. (I dont have stock OEM springs rates, so I would not know where to point you in the right direction.) Kbee doesnt provide different springs rates, they come standard as you see in the pictures. But what you can do is buy Swift Springs coilover replacement springs, not a problem. I suggest to get a shorter front springs, so you have more ride height adjustable. (Most people say its not low enough for them!). These coilover are more for streets then it is for track. They offered 7/6Kgmm spring rates to provide a better ride on highways, and daily drive usage, and for "sometimes" hit up the local track events. It seems your very deep into track racing, then you are for comfort. Just keep in mind that these might not be the coilover your looking for, only because it seem like you need something a bit more HARDCORE then mine.
Kbee builds there own stocks/dampers, and offer it to other top leading brands like Buddy Club's, and others. Stocks are made in Korea, but everything else is built/engineered in Japan.
At 1st they we're noisy, but once the thrust sheets break-in, the car is quite as it can be. Not too many company provide metal thrust sheets, most coilovers do make noise, and only way to fix it, is to buy metal thrust sheets. The noise comes from the springs compression, as the springs compresses and decompresses, the spring rotates which makes a binding noise, like a knocking noise. After it break's'in you'll be fine.
As for price, it is posted.
$899 shipped in US
$899 shipped in California
$850 local pickup in Socal
We have 0 left instock.
Please let me know if they are any further questions,
Thanks,
Tuan @ A Spec.
