View Single Post
  #37 (permalink)
Old 12-29-2007, 01:01 AM
smeister's Avatar
smeister smeister is online now
smeister has a spectacular aura aboutsmeister has a spectacular aura about
I will PM you about the price. It takes me two days.
First day, I take the headlight apart and I prep and paint the housing and whatever needs to be smoked. I also cut the reflector bowl and drill all the mounting holes and do a test fit. I then spray paint the modified reflector bowl. I let all of this dry over night so there wont be any chips or cracks later on. I also use high heat paint so no worries with heat ever.
Second day, I mount the projectors and take apart my car so I can mount the headlights and do the alignment and tightening on the hardware. After the cutoff is perfectly straight, I check again to make sure all the nuts are tight and I put my car back together. All is left then is putting the dog bowls on the projectors and putting the headlight back together with the new butyl based sealant.
The last retro I did, took me one weekend. The reason it takes me two days instead of one is because I let everything dry overnight.
__________________
I do HID Retrofits!
*** HID Retrofit SERVICES ***
DIY: HID Retrofit with FX35 Projectors
More HID Retrofits Competed
My Honda Fit DIY and Reviews BLOG
Gooing back to STOCK! Got a few things for sale still...
