Quote:
Originally Posted by Mugen Mojo
I got to compete again last weekend and I came in 1st place! I only had one other person in my class but it was a Mini Cooper so I guess you can say that the Honda Fit can hold it's own. Here are the results... http://houscca.com/solo/results07/08REG01B.TXT
Goodwork.
STF is likely Street Touring F class which is only for your local area.
STA or STB is for higher powered cars and F for lower power cars.
Normally Street Touring for the Fit is STS but there are also Street Touring X, U and other classes for two door models.
What are your modifications so far on your Fit Sport? Normally if you have a completely stock car you can run in either H-stock or in STS. H-stock doesn't allow for much modding except for any Cat back exhaust and any front swaybar, but you can use stock sized rims and R compound tires like Kumho V710 205/50-15. STF likely allows for some mods but street tires rated 140 treadwear or more.
If you look at the H-stock competition it's pretty tough in your area. If you look at G-stock you can see how the experienced MINI drivers with R compound tires did. Also very competitive.
As you gain experience you'll improve, keep at it. Try to walk the course as much as possible before your runs and practice as much as possible to get to know your car well.
