Quote:
Originally Posted by RubyQQ1211
Can anyone explain the Spring Rate (lb/in)? I am assuming the higher the number = stiffer ride?
That is correct sir. And the way I got my numbers is taking the information from the web sites of each company and converting them all into lb/in from kg/mm. The equation goes as follows:
kg/mm = X lb/in = Y
X/.0179 = Y
Reference:
Online Conversion - spring rate conversion
