Spoon Sport SW388???
Old Jan 30, 2006 | 12:19 AM
dougiepants's Avatar
Avid FitFreak Poster
correct offest for Fit is +48 ?
Old Jan 30, 2006 | 03:25 AM
RagingAngel's Avatar
You can use up to +35mm on it. Infact that is what is used to fit the twinblock calipers.
But it still requires what looks to me like 20mm spacers to clear it ontop.
And no it doesn't stick out like a set of daytons....
Old Jan 30, 2006 | 09:59 AM
Well what is the OEM offset spec? That is what I'm trying to stick too. Since the Fit Sport is coming in a 15x6.5. I am curious to know if that will be a +35 or +45. That is what I am trying to copy for the correct SW388 wheel selection
Old Jan 30, 2006 | 10:48 AM
VelociRacer's Avatar
It is actually a 15x6" factory wheel on the Sport, most likely +45 or +48mm offset.
Old Jan 30, 2006 | 11:52 AM
So which would be ideal with running a 205/50/15 with? the +45 on a SW388 15x6.5 or +35?
Old Jan 31, 2006 | 11:23 AM
I just noticed the SW388 looks just like th Rota SlipStream which is available with +40mm offset that should be the safest guess on the Fit. I don't know how durable/expensive the 15" Spoon SW388 @ 8.6lbs, but Rotas are some of the lightest (11.9lbs) and most durable 15" wheels for the money out there.
Spoon Sport SW388
Rota SlipStream
Old Jan 31, 2006 | 11:54 AM
yeah I have delt with almost all of the Rota lines. I am just going for the real look this time with this car....
Old Jan 31, 2006 | 01:36 PM
mav's Avatar
mav
Senior Member
My guess is that the offset is +45.
Old Jan 31, 2006 | 02:10 PM
well the more and more I'm reading on this site. it is saying +35 for the 6.5
Old Jan 31, 2006 | 02:48 PM
mav's Avatar
mav
Senior Member
Maybe you should call up AJ Racing in Canada (http://www.aj-racing.com). They're a Spoon dealer and should know more, then again the Fit is not out quite yet so you may have to wait until April.
AJ is a very good shop and has a very good rep in the S2000 enthusiast cirle.
Old Feb 1, 2006 | 10:27 AM
I have and still waiting to hear back from them
Old Feb 2, 2006 | 12:22 PM
myfit.org's Avatar
i poted in your other post, but ill look at the Spoon Race car this evening and let you know whats on it, i dont recall what it is off hand
Old Feb 2, 2006 | 09:53 PM
myfit.org's Avatar
ok, the fit race car is running a stager. +45 in back, and +35 in the front. alternates 15 or 16in rim, just depends on what tires are good, more or less.
Old Feb 2, 2006 | 10:45 PM
hmmm interesting. well this is throwing me for a loop then one which to purchase. I'm wanting to upgrade to the Spoon Calipers too, but I hear you have to run ITR items aswell I think
Old Feb 2, 2006 | 11:32 PM
myfit.org's Avatar
FYI: The stock JDM fit uses alot of the same hub parts, and rotors of an EG civic.
Old Feb 3, 2006 | 03:41 AM
stock offset for 1.5S
Disregarding the SW388 for a moment the 1.5S has a +53mm offset for stock.
But like everybody has suggested with offsets, you can't really go wrong unless you do something crazy like a "0"
Old Feb 3, 2006 | 12:02 PM
hmm well I am going to be curious if the NA Fit will have all the same parts as the JDM or Euro ones??
Old Feb 3, 2006 | 12:53 PM
Jonniedee's Avatar
The intake and beauty cover on the NA engine are significantly different than all other markets - just look at the pictures. Now which other parts constitute the other 30% of parts specific to the NA model are unknown - unless someone has a Honda document somewhere that states the items in question?
Old Feb 3, 2006 | 01:03 PM
myfit.org's Avatar
once honda releases the car, i can cross reference the US and Japan Honda parts program and find out whats different, if needed.
Old Feb 3, 2006 | 01:29 PM
the_saint's Avatar
I think that would be a handy bit of information.
