Thread: Trailer hitch?
View Single Post
  #50 (permalink)
Old 01-30-2008, 11:54 AM
Polish's Avatar
Polish Polish is offline
Polish is an unknown quantity at this point
Quote:
Originally Posted by manxman View Post
Well, that's good news- but which brand carrier carrier did He buy that does not scrape? There seem to be lots of brands and designs. Good luck!
Look at Etrailers.com they are all almost identical. The design can't really vary at all because of the confinements. It has to bolt to the same 3 bolts and the center of the hitch has to be, well, center. Any small differences are going to be negligible.
Quote:
Originally Posted by john trials View Post
If you get a hitch mounted cargo carrier, will it block the rear tail lights? That would be my concern. If the driver behind you cannot see the brake lights, that could be unsafe...I know there is the high-center-mounted brake light, but I'd still be concerned.
The cargo carriers are flat and when slid into the hitch will be bumper level, not even close to the tail lights at all. Not to mention they aren't that wide either. You'd have to pile stuff up REAL HIGH to even come close to blocking the lights.
After speaking with some people I am just going to make my own cargo carrier. Spending $130 for a simple flat panel with a 1 1/4" square tube attached to it is insane. Not to mention something that I will likely only use one time. So I will get my own square tubing, some angle iron, and plywood and bolt together something the exact size I need. I'll try to remember to post pics. I will be buying the hitch though $90 is fair to me.
__________________
Corey
ÑHßP Fît Špørt 5mt •6-26-07• Mod List
