Quote:
Originally Posted by martymcfly
The tether doesn't seem to fit the honda locking cap. I am wondering how you guys took it out? Did you just cut it? I can't figure out how to unbolt the screw on the gas lid.
The tether is easy to remove from the gas cap cover with an ice pick or other similar tool like a thin nail. It is attached to an anchor mounted on the gas cap cover by a simple pin that can be removed without damaging anything by pressing it up and out of the anchor from underneath. Locate the bottom of the pin under the anchor and simply press it up with the ice pick or nail. It comes out and you can save it, the tether, and the EOM gas cap incase you ever want to re-install the EOM cap and tether.
