View Single Post
  #15 (permalink)
Old 02-09-2008, 12:29 AM
espo79's Avatar
espo79 espo79 is offline
espo79 will become famous soon enough
step one is obviously jacking up the car and removing the tire. I started on the rear driver side tire:
here is a shot from the back(above).
This is the 14mm bolt you have to unscrew to slip the shock off. After unscrewing i had to pop it out. In the pic below you can see how i used a jack for support which helped me get it out...
This is what it looks like once popped off and stock spring is taken out. (below)Just apply some elbow grease to push down and pull out the assembly.
always look at the difference it makes it even more worth the money!!!
make sure you put the rubber pieces on the new spring and put them back in the way you took them out.
put the bolt back in and tighten!!!
shes beautiful mang
Now take a break and hope that when you do the front you dont go into a panic and start making new threads like the one that this thread is titled hahahah!!!
Not too many pics here but to give you the jist of it:::
thats it hahahah no really im not gonna go into detail as its all in the skunk2 diy . Im mainly posting this so someone can combine all the diy lowering into one thread with all a bunch of pics and instructions from all ...Hope this helps!!!!!!!!oh yeah ciburri rules hahahahah
__________________
