View Single Post
  #1 (permalink)
Old 02-14-2008, 07:17 PM
Sid 6.7's Avatar
Sid 6.7 Sid 6.7 is online now
Why so serious?
Sid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to live
Red "H" Mod ***56k, Why Bother?***
EDIT: I am updating this original post.
The methods are discussed in a few other threads scattered about, but I will rehash them here.
As for the front, here is what I did: I started by removing the pop up tabs on the top of the bumper cover than are under the hood indicated by the yellow circles.
I then lifted the top of the bumper cover up and reached in and popped out the 5 tabs on the grill indicated by the red. Simple as that.
As for the rear: I opened up the hatch and looked into the area above the license plate where the license plate lights are. I then used a long flat bladed screwdriver to break off the two rivets holding on the plastic "H" and the emblem just fell off.
For the front emblem I used a flat piece of chrome PVC used for chrome rocker panels on like Cadillacs and such. I then covered the chrome PVC with red reflective vinyl. The chrome PVC gave a nice flat background to work with. I then drilled the two holes in it so the posts on the back of the "H" could stick through and line it up right.
I used reflective red high performance vinyl and 3M double stick tape to reattach the "H" emblems.
Sponsored Links
