sway bar endlink
Old Feb 15, 2008 | 12:57 AM
FELIXY69's Avatar
sway bar endlink
i need a front sway bar endlink that i can adj. the length
after installing BE sway bar, i felt that it is rubbing on the lower arm, and the T1R end link that came with the t1r coilover arn't adjestable.
so i need one that i can make shorter, bringing the sway bar higher from the lower swing arm.
any help would be great
thanks
Old Feb 15, 2008 | 03:21 AM
SPON FIT's Avatar
Old Feb 15, 2008 | 04:31 AM
FELIXY69's Avatar
$155 seems really expensive !!
and those looks really long and doesn't seem like they have enough adjestment.
Old Feb 15, 2008 | 07:48 AM
SPON FIT's Avatar
easy killer,just trying to help
Old Feb 16, 2008 | 11:21 PM
FELIXY69's Avatar
thanks for the help
here are pics of the rubbing sway bar
T1R endlinks
Old Feb 22, 2008 | 03:56 PM
Skimmer's Avatar
You could take the endlinks you have to a machine shop and get them cut and threaded in the middle and joined with a threaded coupler. That would do the same thing as the Powergrid endlinks but probably cheaper.
jjrf
Dec 6, 2015 12:52 PM
appleica
Dec 6, 2012 03:26 AM
hehn
Aug 25, 2010 02:44 AM
pr0jectezek1el
31
Aug 4, 2008 11:45 AM
igarage
Jul 30, 2008 12:02 AM
