Actually if you do check your owners manual, it states you CAN do multiple downshifts. All you need to do is first be going slow enough to engage a lower gear such as second, and be in fifth. It states to pull the left paddle twice, pause, then pull it again and it will go directly to 2nd. this ONLY works in M mode though... hope this helps
