View Single Post
  #203 (permalink)
Old 03-13-2008, 05:46 PM
StormSilverGD3's Avatar
StormSilverGD3 StormSilverGD3 is offline
StormSilverGD3 has a spectacular aura aboutStormSilverGD3 has a spectacular aura about
Quote:
Originally Posted by smeister View Post
Interesting for the Eibachs the instructions ended up looking with the packed coils up top.
Eibach springs are a progressive rate. The Tanabe, as well as most other japanese springs I have seen, are not.
That is my own conclusion for the tighter-wound coils being together. With the compressed pack at the bottom, there is the ability for the spring to travel with the shock but the diameter of the springs the same the whole way down and the unforgiving coils at the bottom keep the spring rate from changing.
As with the Eibach Pro Kit, the tighter coils are up top and a larger diameter. So, the stiffness and spring rate changes as the coil compresses.
I don't know if that's a 100% accurate assumption, but, it is the logical process that went on in my mind.
I am considered going with the GF210 springs. I just want a slightly lower stance but a noticeable amount of stability in the corners.
__________________
The Fit is GO!
