Quote:
Originally Posted by pcs0snq
I also noticed this week that by down shifting, not just coasting in in 5th or neutral to a stop, the Fit ECU will do a better job of sending ZERO fuel into the engine. 5th only works to about 30mph.
ooops!!!!! I just noticed this ^^^post...hmmm what timing I have
so now to overindulge....care to elaborate more on this?
Should I jump down to 4th and ride out 30mph down? And if so does that mean that all the gears would do this cutoff above a certain threshold?
Something slightly higher than idle would be the threshold I suppose, unless it changes for each gear.
