Adjustable Coilovers Illegal in Hawaii
Old Mar 28, 2008 | 11:46 AM
raton's Avatar
I went to a Rims/Tire/Audio place (don't wanna name the shop) the other day and while talking with the installer about possibly getting coilovers/springs...he said that adjustable coilovers was illegal in Hawaii. That can't be true, can it?
Old Mar 28, 2008 | 12:02 PM
cojaro's Avatar
Car aesthetics must obey laws - Features
Apparently you need a "Reconstruction Permit" to allow for any modifications.
"According to the Hawai'i Administrative Rules Title 19 Department of Transportation Subtitle 5 Motor Vehicle Safety Office Chapter 134, the purpose of reconstruction permits is to show that the modifications put on vehicles are deemed safe for public highway usage."
That applies to any modification.
That sucks hard.
Old Mar 28, 2008 | 08:05 PM
08FitSport's Avatar
That sucks hard.
s19-134-5 (c) states
"Replacement of previously approved equipment items of components with items or components which are substantially equivalent in design, mode of operation and appearance shall not require reinspection and approval.
The so called coil overs are similar in design to the oem strut and coil and shock design ( so unless your license plate falls below 12" from the ground you would not need recon. )
Old Mar 29, 2008 | 02:30 AM
MINI-Fit's Avatar
Adjustable coilovers are not illegal by themselves. Just install them at stock ride height and no one can easy tell that you have them installed.
You are not required to get a recon sticker but you can if you want.
Do a minimal drop maybe 1/2 to 3/4" and you are still fine. Keep a low profile.
Slam it and you might be stopped by the police to check for a recon sticker especially if you go cruising in Waikiki (not a wise place to drive your lowered ride).
Dark tint is illegal for passenger cars but it doesn't mean people don't exceed the 35% limit.
Old Mar 29, 2008 | 06:22 AM
raton's Avatar
Wow! Thanks! Too bad lowering (not only in Hawaii, but in general) have a few complications--recon, tire-ware, rubbing, scrapping/bottoming-out and avoiding HPD attention w/o a recon. All solvable problems...oh well, maybe one of these days...
I did a google search on "reconstruction permit in hawaii" and found some interesting links. The best one was from the ScionLife forum [ScionLife View topic - RECON PERMIT].
A post from the above link had one member call and talk to a guy from the Recon office. He asked a bunch of questions about different types of modifications & how they apply to us folks in Hawaii. Here's a cut-n-paste from a post in the above link. Some interesting stuff...
Originally Posted by crj341
I've heard a lot of contradictory information from friends, etc, so I decided to go to the source and call the recon office. I talked to Kevin down at the recon office about what mods you can and cant do, and of those which ones require recon. I hope this will clear up the misinformation that you might have heard and help you plan your next or current project and not be dissappointed cuz you didn't pass.
Do I need to get recon for a turbo/supercharger?
No. Whether it comes as a kit or you put it together yourself, you can legally put a turbo/supercharger on your car and DO NOT have to get recon. However if you have to get recon for one of the reasons below, just make a note of the turbo/supercharger.
Are engine swaps legal, and do I need to get recon for it?
That depends. Yes engine swaps are legal, but that does not necessessarily mean you have to get recon. If the engine you are swapping in has the same number of cylinders as the one it is replacing, recon is NOT required. It doesn't matter if the engine you are swapping in is turbocharged. For instance, you want to swap a SR20DET into your 240sx. This does not require recon. However, if you want to swap a RB26DETT into your 240sx, you WILL need recon.
Can I put on rims bigger than 1.5" compared with stock?
Yes, but you will have to get recon. You can go as big as you want to, but the wheels have to be able to turn and not rub the fenders or wheel well when turned.
Do I have to get recon for my headers/exhaust/intake?
No. These are not recon items. And even if you did, any intake/exhaust will likely pass as long as the exhaust isn't too loud (they don't have any DB meters down there, they just listen to it). If your car is fitted with a catalytic converter, you will still need a cat, but you can use an aftermarket high flow type and still not need recon.
Can body kits/panels/hoods be installed?
Yes, and you don't need recon. One caveat here though, if your fiberglass/carbon fiber hood does not have provisions for windshield washer nozzels and you don't put them in, you would not pass safety, let alone recon.
Are coilovers/lowering springs legal?
That depends. Any time you have suspension work done to your car, you will have to get recon. You will need to have an alignment done within 30 days prior to your recon inspection. Make sure you bring a copy of the alignment sheet with you. Your suspension must be able to be aligned within stock specifications. Your car will also be subjected to a "bounce test" to check for adequate suspension travel. They typically test this at a front corner by pushing down on the bumper. You need to have VISIBLE (not necessarily 2 inches) of suspension travel. If your springs are too stiff, you will likely not pass.
Are headlight/tail light swaps/conversions legal?
Yes, as long as it says DOT on them. Simply doing a headlight/tail light swap does not require you to get recon. If you modify the donor headlight, then it is no longer DOT legal. Aftermarket HID's are also legal, though you may need recon for this. They have a light meter to make sure it's not too bright.
Are clear corner lights legal?
No. The lights MUST have an orange reflector at the front corners and corresponding red reflectors at the rear. This is a FEDERAL LAW. Simply putting in an orange bulb DOES NOT make it legal. Most of these aftermarket lights do not have DOT on them, and therefore would not pass anyway. If you modify a DOT corner light by taking the orange reflector out, it is NO LONGER DOT legal.
Can I run nitrous?
No, and it can't be made legal by going through recon. If you did have to get recon for suspension mods, and they happened to find a nitrous line or bottle, you will fail.
Can I change my car from front wheel drive to rear wheel drive?
Yes, but you will need to go through recon as this will require modification of the vehicle's suspension. If you did a hack job with the conversion and the inspector deems your car unsafe, then you won't pass.
If there's a version of the car with a different drivetrain, can I use it?
Yes. If the car came from the factory with the option of a manual or automatic transmission, you can swap one for the other without getting recon. You could also do a 4 wheel drive conversion on your 2 wheel drive truck if there was a 4 wheel drive version of your truck from the factory, provided the parts bolt in without requiring custom fabrication. If custom suspension mounts need to be made, or you use aftermarket suspension components, then you need recon.
Are intake manifolds/cams, pistons, etc legal?
Yes, and you don't need recon. There's no smog testing in Hawaii, so you don't need an affadavit showing that the part is 50 state legal. But be aware that if it says "off road use only" on any of the parts, and the inspector sees it, you will likely not pass recon even if you were trying to get it for something else.
Do I need an affadavit for all of my modifications?
No. Affadavits are no longer required.
Is there a headlight/liscense plate height requirement?
Yes. Headlights must be at least 22" off the ground to the center of the headlight housings. You must have a front liscense plate which must be at least 12" off the ground.
Do I have to get a recon inspection every year?
No. It's a one time only thing UNLESS you mod your car again. If you do, then you need to get another inspection. If you return your car to stock again, you no longer need the recon sticker.
If a cop pulls me over saying I need to get recon even though I don't have any recon items on my car, what happens?
If you got pulled over for a non recon item, you can contest the ticket in court and you will win. Kevin says many of the cops don't have a good handle on the recon law themselves. Keep in mind though, if you already have recon and do another mod to your car that requires recon, then you need to get another recon inspection. If the cop nails you on something you just installed, then you're SOL.
Hopefully this will clear up a lot of the BS that has been floating around. If anyone has any questions about a modification, it is in your best interest to call the recon office (733-2542) and speak to an inspector BEFORE you spend the time and money. As you can see, you can do a lot of mods to your car and not need recon. But if your mod requires it, make sure your mod will be able to pass by reading the thread.
Old Mar 29, 2008 | 07:36 AM
MINI-Fit's Avatar
Yes, Recon info here too:
recon forum information FAQ - ForumsHawaii
Some rules are pretty lame like the bounce test.
Some stock cars would not pass - anything with stiff suspension.
Check out all the raised trucks on the road with obviously altered suspension and big wheels. How many have recon stickers? 1 in 10 maybe?
Old Mar 29, 2008 | 08:00 PM
08FitSport's Avatar
http://www6.hawaii.gov/dot/highways/...024%201986.pdf
This is the recon rules. It is my understanding that the only reason you will get pulled over for recon. is cosmetics (rims sticking out of the fenders, car to low or to high, carbon fiber hoods etc., outrageous wings or spoilers) but, if you get a ticket and have to go get clearance from the recon station they'll check your car for any thing after market even tail or fog lights so keep your receipts and try to buy dot lights if upgrading.
Old Apr 15, 2008 | 06:56 AM
ha-y-nferio's Avatar
shoot, when i moved back home from the mainland, i had to get a recon inspection on my civic. they said it was because the car was lowered. anyway, i ended up having to get an alignment done, just to be able to pass recon. i also had to remove my jdm foglights from the front bumper, and switch back to the stock headlights from the SiR ones cause of the amber strip. it's a real nitpicky pain in the a$$ process. but once you pass, it is good for the life of the car. you don't have to get recon, but i wanted to save myself some headaches later on. as for coilovers being illegal in Hawaii, i dunno about dat. as long as you get an alignment done and have them installed correctly it should pass safety and recon, unless you do it the other way, and skip recon altogetha. but we won't go into that that's why i'm keeping the Fit stock for a while...i like not having to worry about this ish every year.
Old Apr 15, 2008 | 12:41 PM
tsxdriver's Avatar
and that's why i have air suspension on my tsx! haha!
Old Apr 16, 2008 | 07:07 AM
hehe, that's really not a bad idea.
Undercover
Apr 17, 2011 03:42 AM
[09]FITBBP
May 11, 2010 04:11 PM
Squad808 Fit
Dec 13, 2008 08:57 PM
moondog
Nov 15, 2008 06:27 PM
SukebePAUr
Jul 18, 2008 09:47 AM
