View Single Post
  #11 (permalink)
Old 04-08-2008, 09:02 AM
mahout mahout is offline
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
Quote:
Originally Posted by yeamans17 View Post
you shouldn't need to. once you have them in, just make sure all the pressures are set properly (at least above the 27psi where the light kicks on) and drive, sometimes it takes 30 seconds, sometimes it takes 15 miles for the light to go off. Theres no tool the dealership will have to reset the light. I worked in a dealership, and if the light doesn't go out, basically all you can do is try a new sensor
TPMS sensors can be moved from one wheel to another but it is time-consuming and easily broken. Dealers can reset the 'code' recognition (for a price) but the real problem is there are a half-dozen manufacturers and every brand wants it 'own' so the poor owner gets screwed. The cost per sensor is 50 to 75 each so a set will cost $200 to 300. Ain't govm't wonnaful. It won't take long for owners to tape over the 'warning' light or just ignore it so there we are back to owner not taking care of his maintenance required, overloading his tires, having a blowout,crashing, and blaming the tires. Love technology but not stupid technology.
