04-14-2008, 02:18 AM
Quote:
Originally Posted by MINI-Fit
Stock tire diameter is about 23.4".
For 16x7 rim and 1" drop
Best size is 205/45-16 which fits rims 6.5-7.5" wide and has 23.3" tire diameter for best clearance and no rubbing.
See Goodyear Eagle F1 GSD3 $140 each 280 treadwear
Max Perf Summer tire for those that want very good wet and dry handling
In 205/45-16 (ultra HP Summer tires)
The S.Drive is $91 each 300 treadwear, not as good on wet handling.
General Exclaim UHP $67 each 380 treadwear while not as crisp for handling it works well in wet or dry and is more comfortable for street use
Michelin Pilot Exalto PE2 $144 each 240 treadwear, better blend of good handling wet or dry and good comfort, but higher price and faster wear.
215/55-16 fits rims 6-7.5" wide but is way too tall 25.4"!
225/50-16 fits rims 6-8" wide but is way too tall about 25"!
205/55-16 is also tall about 25".
For wider than 205 then
215/40-16 fits rims 7-8.5" wide, smaller than stock tire diam. 22.8"
1/2" more wheel gap than 205/45-16. Goodyear Eagle F1 GSD3
215/45-16 fits rims 7-8" rims, tire diam 23.6"
225/40-16 fits rims 7.5-9" wide, is smaller than stock at 23""!
No tires match this size at tirerack.com and Toyo Proxes T1R are out of stock on this size
It's not worth the effort or risk to put different sized tires on front vs rear.
Same size on each is best.
Functionally the 205/45-16 will work fine. You also get a better selection of tires at decent prices.
A 215mm wide tire is only 10mm wider and you compromise a smaller or taller tire diameter which can look off balanced. You don't really gain that much performance for 10mm wider. 40 series sidewalls are stiff so handling is better but ride quality can suffer and if you have any potholes or bumpy roads you risk damage to your tires, rims or suspension if you hit any road hazard at speed.
Very Detail Information THANK YOU SO MUCH!! I know what I'm going to do!!
__________________
My Fit is RED !!!
North East Fit Club, Can we join together to make one BIG group???
"President" of NEFC
