View Single Post
  #3 (permalink)
Old 04-21-2008, 01:13 AM
F'it_ImFromTx's Avatar
F'it_ImFromTx F'it_ImFromTx is offline
F'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to liveF'it_ImFromTx relies on Rep Points to live
part two: short ram intakes
these are the few that illusive forgot, well he got the main ones, these are the ones that arent so well known.
1. k&n typhoon short ram intake $235.00 on nopi.com
(copied from k&n's site)
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon's have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range.
**if you havent already seen the threads about it, dont buy this intake!!!**
2. hks super mega flow reloaded intake $139.00 on hopupracing.com
(copied from hopupracing.com)
HKS Super Mega Flow Reloaded intakes have been engineered to dramatically reduce the restriction caused by factory air boxes. The redesigned filter assembly has the same patented Super Funnel design from the previous generation, but also features new technical advances: - Filter cage allows for 30% more intake surface area - Aluminum back plate for added strength - Sealing ring reduces contaminants from entering engine - 3 Layer, triple density dry filter element
3.zero 1000 power chamber $149.00 at jhpusa.com
(copied from jhpusa.com)
The Zero 1000 Power Chamber Intake System is a must upgrade for naturally aspirated engines. the uniqueness of this intake system is its design, it ustilizes an enlarged dry carbon chamber and a spiraled filter. The air is sucked in through the filter resulting in a swirling effect. This swirled air is then captured in the chamber where it becomes compressed, which will cause the air to become denser. Increased density in the combustion chamber means an increase in horsepower.
4. hks super suction kit $663.39 at bullerproofautomotive.com
(copied from bulletproofautomotive.com) High capacity racing intake kit made of aluminum. 70mm-60mm piping
5. honda-veni chamber intake $679.77 on bulletproofautomotive.com
(copied from bulletproofautomotive.com) appears to be the sma design as the t1r bmax. i cant find any info on this, it isnt even posted on the honda-veni site.
6.hps (hi pro speed) short ram intake $99.99 on hiprospeed.com
(copied from hiprospeed.com)
Dyno-Proven Performance (Dynapack Dyno Graph is included)
  • Baseline Power - 81.7 whp, Baseline Torque - 83.5 Ft/lbs
  • Peak Power - 86.6 Whp, Peak Torque - 84.4 Ft/Lbs.
  • Max Power Gain @ 5,717 rpm - 5.0 Whp, Max. Torque Gain @ 5,686 rpm - 4.5 Ft/Lbs,
Item Description & Specification
  • Item Condition: Brand New
  • Increase the horsepower, torque and improve the gas Mileage
  • The HPS shortram air intake can help your engine to suck in more cooler air resulting in better throttle response and higher explosive horsepower output
  • Each intake pipe is made with high grade yet light weight aluminum alloy with polishing process, for which ensure the long-lasting quality of the intake pipe
  • Featuring the 3-Ply reinforced SILICONE couplers/reducers, the HPS shortram air intake kit provides stability even the vehicle is in an extreme driving condition
  • With the special cone design and complete sealing bottom, the HPS high performance air filter maximize the air flow and minimize the possible air leak
  • Fits both Automatic & Manual Transmission
7. arc super induction box $420.00 at boomplustoys.net
(copied from boomplustoys.net) i cant find any info on it, but its arc. they are a pretty reputible company
8.h-fit supa sucka chamber intake $295.00 on h-fit.com
(copied from h-fit.com)
Performance Optimization
Knowing that intake air travels in pulses through the intake tract and manifold, H-FIT Engineers decided to harness this effect in order to optimize the air intake velocity and volume. Using the known equations for pressure to velocity relationships (P1V1=P2V2), and the known thermodynamic properties of nozzles, the intake box was designed to meet the required performance criteria.
Air travels into the intake “box” through a large opening. This filtered air then fills the “box”, creating a reservoir of air. This serves as a reserve at lower rpm’s and during sudden throttle plate opening. We have found that this increases throttle response. As the engine RPM increases, the intake air requirements increase, the higher frequency pulsed flow of air through the optimized inlet and outlet ports on the “box” create an increased pressure zone within the box, and an increased air velocity at the throttle body port. The volume of the box was designed to give an internal resonance just prior to VTEC switch over. The optimized port sizing and resonance create a slight “Push” effect on the intake air which forces air into the intake manifold (Helmholtz Resonance). This allows for a more noticeable VTEC effect.
9. apexi power intake $123.00 at optionsauto.com
(copied from optionsauto.com)
The Dual Funnel Power Intake evolved from the highly successful Super Intake. Subtle refinements in the design and filter element resulted in a 10% reduction in pressure drop. Utilizing an upper and lower funnel, the Power Intake reduces air turbulence within the filter and creates smooth air flow into the throttle body. The Power Intake is a maintenance-free dry-type air filter and will alleviate the problem of filter oil from "wet" air cleaners interfering with the air-flow meter. Accept no imitations.
10. afe stageII intake $189.00 on afefilters.com
(copied from afefilters.com) i dont know what to say other than whats on here. there isnt really that much else posted any where on the web.
11. password jdm power chamber intake $249.00 on passwordjdm.com
(copied from passwordjdm.com)
Made of aerospace quality carbon fiber, the Password:JDM Carbon Fiber Power Chamber Intake surpasses any other intake on the market in quality, and in performance. Manufactured here in the USA, the Power Chamber is constructed of the finest carbon fiber, and filter elements currently available on the market. The Power Chamber Intake comes complete with all mounting hardware required to install on any Honda Fit.
Using a unique flared intake tube design, the Power Chamber is able to deliver noticeable gains across the entire power band. This intake gives you the best of both worlds. The security of knowing you are at no risk of hydro-lock, the power delivery that most cold air intake systems can only dream of, and the unmatched style of a genuinely unique intake system.
Through integration of form and function, the Power Chamber will make a bold statement about you and your vehicle. Spectators all around will notice your fine taste in performance products, and will envy your engine bay's unique styling!
*Requires relocation of battery from stock location or use PWJDM Fit Battery Relocator kit w/Odyssey 680 Battery.
SPECIAL OPTIONAL PACKAGE PRICING, FREE SHIPPING
Get everything you need to complete the install! For a limited time, you may purchase the Password:JDM GD3 Fit PowerChamber intake, Password:JDM Battery Re-Locator Kit, and the Odyssey 680 battery with brass terminals for a discounted price of $439.99 PLUS FREE SHIPPING anywhere in the USA 48 states! This is an introductory offer so get yours today!!!
Dyno proven gains!
+ 5.0 hp
+ 3.8 ft/lb
Dyno performed on completely stock 2007 Fit (stock header, stock exhaust, etc)
well, i think those are all the short ram/ chambered intakes for the fit that i could find that illusive didnt already post. coming up next, cold air intakes.
__________________
Leader of the Filthy Fit Crew-08 NHBP Sport
Last edited by F'it_ImFromTx; 04-21-2008 at 03:42 AM. Reason: update - new intake added
