Quote:
Originally Posted by cavie187
How lean? What was the wideband readout for a/f?
After the test pipe, the A/F jumped to about 13.7-13.9 with I/H/E.
Quote:
Hmmm what he said ^ .. and what method would you suggest to add fuel? Someone said something about the Apexi Neo? and i've also heard that if you use the neo you will need to adjust timing? Whats your take on this..?
Emanage Ultimate or Apexi Neo will do the work for increase or decrease fuel trim.
As for timing, Apexi Neo can't do timing so Emanage Ultimate will be the only option for now. We tried to add more timing and it helped in acceleration but not much hp number on the dyno.
Quote:
I'm pretty sure the stock injectors could solve it with e-manage.
You don't need bigger injectors for NA setup L15A. The Emanage will do the magic.
