Quote:
Originally Posted by AJ PwR Jr.
After the test pipe, the A/F jumped to about 13.7-13.9 with I/H/E.
Emanage Ultimate or Apexi Neo will do the work for increase or decrease fuel trim.
As for timing, Apexi Neo can't do timing so Emanage Ultimate will be the only option for now. We tried to add more timing and it helped in acceleration but not much hp number on the dyno.
You don't need bigger injectors for NA setup L15A. The Emanage will do the magic.
Is adjusting the timing absolutely necessary?
