15" 04 Civic EX Alloys: Are they the correct offset for the Fit?
Old Apr 24, 2008 | 04:50 PM
ClaytonS15's Avatar
Are they the correct offset for the Fit? Thanks
Old Apr 24, 2008 | 04:52 PM
TOOL's Avatar
Yeah i belive they will easily fit. Most OEM wheels have a ratehr high offset.
Tyler
Old Apr 24, 2008 | 05:18 PM
ClaytonS15's Avatar
Tyler
Thanks for the feedback. The reason I'm asking is a few weeks ago, I hit and went over a curb at about 5 mph with the right front and since,that I've been feeling a vibration in the steering, I think from the front of the car. I just had the car aligned and replaced the front tires because they were out of round. Now, (after the alignment and new front tires) the car pulls slightly right and still has some vibration in the steering, but not as bad. I've also recently balanced all the tires. What else could cause this vibration? Thanks
Old Apr 24, 2008 | 06:08 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Possible a bent wheel?
You need to take it back to that place. Have the tires roadforced and matched. And the alignment checked. Roadforcing can determine if its a bad tire or bent wheel. My guess is a bent wheel.
If they cant do roadforce, take it to Honda to do it.
Offset wouldnt have anything to do with vibrations. It would be hub bore and sometimes lugs. All Hondas are the same hub bore I believe.
Old Apr 24, 2008 | 06:18 PM
ClaytonS15's Avatar
I think I'll probably take it back to the tire shop as I'm a bit frustrated at having spent $300 for new front tires and an alignment, only to still have a vibration issue.... If that doesn't work, I try a Honda dealer.
Old Apr 25, 2008 | 02:01 PM
ClaytonS15's Avatar
I took it back to the tire place. It turns out after testing and inspecting the rear tires, that all 4 of my original Fuzion VRI tires were severely cupped as a result of the previous owner apparently NEVER rotating the wheels!!! I am replacing the tires will Nokian I3 all seasons 195/55/15. I will report back when I get the car later today.
Old Apr 25, 2008 | 05:42 PM
Posts in the NUUDE
Arent Nokian's winter tires?
Cupping shouldnt cause vibrations. It can cause road noise though.
Old Apr 26, 2008 | 01:16 PM
ClaytonS15's Avatar
It's possible there were other wear problems, the rear tires were definitely the cause of the vibration problem. Nokian is mostly known for snow tires, but they make nice all season tires as well. I'm happy with them. Finally, no vibrating on the highway!
stephenmarklay
Sep 22, 2018 05:35 PM
oiric2006@gmail.com
Feb 15, 2018 07:20 PM
Goettler
60
Jun 29, 2016 10:41 PM
jdmgirl
Jan 29, 2014 05:19 PM
inxsole
Nov 4, 2009 12:55 PM
