View Single Post
  #14 (permalink)
Old 04-25-2008, 10:26 PM
manxman manxman is offline
manxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to live
Quote:
Originally Posted by Rob22315 View Post
Thanks for the ideas, sounds like you have a Sport. On my Base, I don't have any stock MP3 or Aux capability. This unit was a not-so-cheap way to get both without having to pull the stereo. The advantage with this unit is it's an MP3 player on it's own - I don't need an iPod or Rio etc. to play mp3's. I can put the files on a USB thumb drive or an SD card. If the folders/files are properly set up, the stereo thinks it a CD changer but without the CDs. The two risks are - I won't be able to squeeze the cable in without pulling the stereo, and it won't work/last.
I figure since I've already had such a good Fit experience on this forum, I'd risk the $100, try it, and post my experiences as a way of giving back.
Yeah, I figured that you had a Base model, and didn't realize that you were trying to use a "thumb" drive for the storage/playback. Again, good luck- I hope that your eBay thing works out. If it doesn't, keep the "iRiver Clix" and its charger/transmitter in mind. You do have a 12 volt power outlet in the Base, so this system will work without having to connect any cables to the head unit. I am looking forward to reading your review of the adaptor that you ordered.
