View Single Post
  #27 (permalink)
Old 04-26-2008, 02:33 PM
Raaaaaaaaaay.'s Avatar
Raaaaaaaaaay. Raaaaaaaaaay. is offline
Posts in the NUUDE
Raaaaaaaaaay. is an unknown quantity at this point
Quote:
Originally Posted by claymore View Post
There was no mention of 14+ readings ( where did you come up with 14+ readings ?????) 13.7 IS FINE (under all conditions) and WILL NOT DAMAGE INTERNAL PARTS INCLUDING PISTONS, PISTON RINGS, OR PISTON RING LANDS running N/A.
Where did you get 14.0+ AFR's? I simply said 14.0 AFR's. Nothing higher. When I mentioned anything higher I was comparing how high the AFR's were under load as to what cars run when NOT under load.
And 13.7 and 14.0 isnt a big difference. Either way its damn close to 14.0 AFR's.
The correct one is the closest to 14.7 (perfect) without detonation or preignition under all conditions load or no load ALWAYS (running N/A).
Every car is different. Some detonate sooner than others. How do you know this is correct with the Fit?
__________________
- KillerFit #2 -
- iFrame -
