View Single Post
  #6 (permalink)
Old 04-28-2008, 09:54 AM
Sid 6.7's Avatar
Sid 6.7 Sid 6.7 is offline
Why so serious?
Sid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to liveSid 6.7 relies on Rep Points to live
Quote:
Originally Posted by ezduzit View Post
Once again, that is probably the worst place under the hood to locate your filter as far as intake temperature goes.
Even when you're driving and getting some air flow, temps go up in that zone instead of down.
Unless you add another 90 or 60 degree elbow to locate the filter in front of the battery, you're going to sucking hot air.
ez
I didn't see anybody calling this a cold air intake. It is a short ram. And as such, has it's place within the world of intake systems.
If you want cold air, then by all means, spend $350+ on a cold air intake.
If you want a short ram intake, and everything that comes with it, then spend $50 at Autozone or $200+ on a name brand.
At least you have choices.
As far as pros and cons, I'll let those with degrees and such lay into you. Because obviously you beat my knowledge of all things automobile, with my pitiful 15 years in building, street racing and blowing up stuff.
Funny, really. Just because you own a Honda Fit, people assume you live your life vicariously through Fast and the Furious and import mags. As if I was some kind of bench racer, keyboard jockey, wannabe. And that I haven't been there, done that, rode it hard, and put it up wet.
